2008 Ford F-250 6.4L Engine's gone (per two mechanics) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 08-08-2018, 12:59 AM
SueJean
SueJean is offline
SueJean is starting off with a positive reputation.
Unhappy 2008 Ford F-250 6.4L Engine's gone (per two mechanics)
Today my truck took a nosedive on a trip to Fairbanks. Started blowing clouds of heavy white smoke and started running really rough. Took it to a mechanic right away and got the bad news.
Diagnosis: One injector is dead and 2 or 3 more are weak. Compression on 2, maybe 3 cylinders is down to 80%. (Mind ya'll...I don't know what I'm talking about here, just relaying the "facts".) His conclusion: the engine will have to be replaced. He also pointed out a couple of other Fords on his lot waiting for replacement engines @ a replacement cost ranging around $20K.
No warning on this. The truck's been running fine since the DPF/EGR delete last fall and we've been gearing up for a VERY LONG road trip south with our RV in tow.
Background: Bought the truck used in TN in 2014 with 109K miles on it. Currently has 156K miles on it. Our diesel mechanic considers us as "besties", we've seen him so often in the last 3.5 years. The list of challenges on this truck vs our 2001 F250 7.3L has been overwhelming.
Bottom line: We'll be heading out with our 2001 F250 7.3L running as "lead dog".
Last edited by SueJean; 08-08-2018 at 01:17 AM. Reason: Needed to add a little background info.
Old 08-08-2018, 07:31 AM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Very sorry to hear this. Your not alone, quite a few on here lately have experienced the same thing. I know it will be tough but I hope you enjoy your trip and the old girl treats you good.
Old 08-08-2018, 08:00 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
labor is a big chunk of that 20k....and new engines are not put in...they use reman's...which concern me because things like lifters dont necessarily get replaced. the last time I checked..a complete drop in ford reman under 1 part number was 13k before tax and core charge.
the injector problem is common on 6.4's. today's low sulfur fuel just doesn't provide sufficient lube. and new injectors are actually "reman's" as well with questionable rebuild standards....so replacing all the injectors before touring the USA would not necessarily prevent blown injector problems.
do these injectors blow because of wear or high temp as a result of high power demands....seems like there;s no set pattern.
although we do get a lot of blown engines with 6.4's while towing what should be an easy load.
Old 08-09-2018, 07:30 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is online now
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
I would not put a dealer reman engine in it, there are a couple of good engine rebuild places that specialize in the Ford power strokes that would give you a better product than a dealer engine at probably a cost savings, only problem is your up in Gods country and although it might be beautiful, it does have it's drawbacks, and any mechanical diesel service for a reasonable amount of money is not going to happen.
Old 08-09-2018, 08:58 AM
speakerfritz
One of the pros of a ford Renan is that they take any core back. Novelty Renan shops will only accep cores that are easily rebuildable.
Old 08-09-2018, 04:49 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Find a warranted engine from a rollover. No core. Keep yours for spares. Hire a competent individual to Remove and replace the engine.
Spend 6 grand or walk away. The truck is 10 years old. You'll be money ahead.
Denny
Old 08-09-2018, 07:34 PM
Firefighter 1406
I hear you Denny. However when I used to look just for the heck of it it’s hard to find a wrecked one with reasonable mileage for less the $8,000. That’s just for the engines.
not saying somebody might be able to get the hook up for cheaper.
Old 08-14-2018, 09:05 PM
DieselDenny
SUE,
any intelll at all?
Old 08-23-2018, 07:47 PM
dogdays
dogdays is offline
dogdays is starting off with a positive reputation.
Lots of wishful thinking here. 6.4s that fail usually have nearly nothing reusable. The remanufactured engine from Ford runs around $20K and that does NOT include labor.
I don't think there's an easy way out of this mess. Sorry!
R.
Old 08-23-2018, 11:00 PM
DieselDenny
Wonder where this went?
Old 08-24-2018, 05:13 PM
driximus's Avatar
driximus
driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
Have you tried talking to your insurance company? When I needed an engine for my 02 my friend called his dad who is an insurance adjuster. He had access to a nationwide database and found me an engine with fewer miles for my 02 that was close.
Old 09-03-2018, 12:49 AM
BernieP
BernieP is offline
BernieP is starting off with a positive reputation.
Unfortunately the 6.4's are a ticking time bomb and a pile of junk. It was a bridge motor for Ford built on the 6.0 platform but was never as strong as a 6.0. Also the fuel deliver method on the 6.4 is unreliable. Best to check your oil daily as they are prone to filling the crank case full of diesel once the high pressure pump which is in the valley of the engine fails. If you like the rest of the truck and it's in good shape there is a Cumings conversion for it which utilizes the Ford 5R110W transmission if you're willing to spend the $$.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
