Can we talk about weight loss?? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 08-05-2018, 05:04 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is online now
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Hey gang. '14 F250 Lariat, new to the 6.7s. What's the norm? Do we lose underneath weight, with proper tuning!? Fine to run this way until the next stage of losing weight under the hood? Or.. Do we need a total weight loss all at once? 😁Trying to get the full picture of options and plan of attack.
P. S. I know someone understands this rediculous post.
Old 08-05-2018, 06:24 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
You can talk out in the open about deleting on FTE. Yes, you can just do the DPF and tuning to start and leave the EGR in place but in time, it will get sooted up and get stuck in closed. So, it's best to get the plates and get it out of there sooner rather than later so it's still functional when it's time to sell or trade and you want it back in.
Old 08-05-2018, 06:43 PM
bigb56's Avatar
bigb56
bigb56 is offline
bigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to behold
I just started thinking about a 6.7 today, not real serious yet but if my accountant says it's a good move (IRS Section 179 deduction) I just may do it. Unfortunately we have state emissions here so I'll have to keep everything.
I guess sneaking around here the 6.7 forum means I have taken the first step, I feel kinda guilty
Old 08-05-2018, 06:59 PM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
You don't have to fully remove the egr cooler in order to prevent it from sooting off either. If there is ever a chance that it would need to go back stock I would just install blocker plates and leave the cooler in place. Just be very careful removing the egr to exhaust manifold bolts, soak them down with a good penetrant like kroil for weeks when the truck is cooling down to allow it to creep into the threads. You don't want to break those bolts off and create a much bigger job, many people have, mine came out like butter but I had used kroil for two weeks prior every time I remembered.
Old 08-05-2018, 07:02 PM
schlepprock250
Thanks. I wasn't sure about having to be stealthy lol. I haven't had the 14 Lariat very long and still have some warranty remaining. I'm just trying to research and get a handle on things. I'm thinking of weight loss 😁 more from a reliability standpoint. Not looking to build a race truck. But a little more crispness and towing power would be welcomed. I don't want smoky tunes or too hot to run tunes. I'm thinking of a delete pipe and leaving the stock end pipe and tip. Been doing lots of reading but a lot of what I'm reading seems to be dated and like fresh opinions.
Old 08-05-2018, 07:31 PM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Originally Posted by cappa View Post
You don't have to fully remove the egr cooler in order to prevent it from sooting off either. If there is ever a chance that it would need to go back stock I would just install blocker plates and leave the cooler in place. Just be very careful removing the egr to exhaust manifold bolts, soak them down with a good penetrant like kroil liquid wrench for weeks when the truck is cooling down to allow it to creep into the threads. You don't want to break those bolts off and create a much bigger job, many people have, mine came out like butter but I had used kroil for two weeks prior every time I remembered.
Fixed that error for you.
Old 08-05-2018, 08:41 PM
Sader's Avatar
Sader
Sader is offline
Sader has a good reputation on FTE.Sader has a good reputation on FTE.
Originally Posted by dirthawg View Post
FIXED that for you...
AEROKROIL is tha shiznit.
Liquid Wrench is second best.
Done amazing things with both.
Old 08-06-2018, 05:50 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.fordboy2 is gaining momentum as a positive member of FTE.
Following along to get information
Old 08-07-2018, 06:00 AM
KC8QVO's Avatar
KC8QVO
KC8QVO is online now
KC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to all
This write up I did on replacing the EGR cooler core may assist with anything relating to working with the EGR circuit. Note the 4 rules early in the post after the first 7 pictures (picture 8 is included in the rules section).
https://www.ford-trucks.com/forums/1...ers-guide.html
I have not seen that video before. Thanks for posting it. I watched the whole thing.
Please note that, when referencing this video, they did a 3 hour test. The references where people are saying penetrating oil works the best are usually between a week and two weeks. I do not think that this test - at 3 hours soak time - is accurate. Of course heat is going to work better than anything - expanding metal by temperature happens pretty fast, as opposed to the time it may take for the penetrating oils to really work their magic.
To get more accurate results we would need a test over the course of at least a week with daily applications, as opposed to hourly applications.
I agree with the heat method, though. If you read through my post on the EGR core replacement - even after north of a week's soak time with PB Blaster I had a manifold bolt stick. I tried a propane flame on the manifold with no luck. I have since bought an oxy/acetylene outfit just for this purpose, though I can multi-purpose it for welding/cutting also for the time being.
Old 08-07-2018, 07:36 AM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
This is what I have done, left the stock tip in place for the incognito look. Course soon as you start it, it is clearly different sound from stock. Some like it some don't. I added a big walker muffler and FTE resonator inline and it is almost as quiet as the stock system was.
Old 08-08-2018, 02:02 PM
Deuce40s
Deuce40s is offline
Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.
Lots of us have deleted, ask any questions you have. It can be a daunting procedure. I did the EGR block off plates, race pipe with Donaldson muffler and stock tip. It's almost as quiet as stock. I wanted my interior to look as stock as possible so I did the EZ-lynk tuner and no extra monitors or gauge pods.
Old 08-10-2018, 06:33 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
My truck lost weight this summer just before vacation after battling several issues for almost two years, which Ford just couldn't get a handle on. I couldn't afford to trade it and had to have a reliable truck for the summer trips, so that was really my only option. Haven't looked back.
Old 08-10-2018, 06:49 PM
Magnolia Tom's Avatar
Magnolia Tom
Magnolia Tom is offline
Magnolia Tom has a great reputation on FTE.Magnolia Tom has a great reputation on FTE.Magnolia Tom has a great reputation on FTE.Magnolia Tom has a great reputation on FTE.Magnolia Tom has a great reputation on FTE.
I'm like Deuce...got a race pipe with a Donaldson muffler and left the factory tips. I have the block off plates from no limit. As suggested before, soak all the egr bolts ahead of time. I did mine for 4 days... every morning before I left and every afternoon when I got home. When I finally decided I had the guts to attempt to loosen them, I drove the truck 20 minutes beforehand to heat everything up. They all broke loose fairly easily except one which needed some extra force and an extra shot of PB blaster.
Old 08-11-2018, 11:12 PM
KC8QVO's Avatar
KC8QVO
Which one hung you up, just curious?
Old 08-12-2018, 07:38 AM
Magnolia Tom
The bolt on the lower pipe closest to the firewall on the exhaust manifold
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
