How many miles do you have on your stock 6.0 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 07-29-2018, 11:01 PM
bfloyd4445
bfloyd4445 is offline
bfloyd4445 is starting off with a positive reputation.
Just curious on how many miles we have driven our stock 6.0's. Mine has hardly any at 103k
Someone in another thread mentioned that a guy with a 6.0 has almost a million miles!
Old 07-30-2018, 12:36 AM
wedge542's Avatar
wedge542
wedge542 is offline
wedge542 is gaining momentum as a positive member of FTE.
350k here.
Old 07-30-2018, 02:27 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.
154,800 on mine.
Old 07-30-2018, 08:10 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.
Now when you say stock...do you mean as it left the factory or not tuned and such? I've got 200+K on mine but had head studs an egr delete at around 150k or 160k...can't remember. Have over 4000 hours on the clock.
Old 07-30-2018, 08:14 PM
stinks the truck dog
stinks the truck dog is offline
stinks the truck dog is starting off with a positive reputation.
197638 run it like I stole it with an 8000 lb. excavator on a trailer
Old 07-30-2018, 08:19 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
JaySVX is a splendid one to beholdJaySVX is a splendid one to beholdJaySVX is a splendid one to beholdJaySVX is a splendid one to beholdJaySVX is a splendid one to beholdJaySVX is a splendid one to beholdJaySVX is a splendid one to behold
My 6.0 went to 215k before hte oil cooler failed. While I was replacing it, I deleted the EGR, and now have 233k on an otherwise stock 6.0.
Old 07-30-2018, 08:54 PM
DPorter
DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
820,000 km, or over 500,000 miles.first engine went 758,000 km then eat a lifter so i installed a 160000km junkyard engine and carried on.
Old 07-30-2018, 09:45 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Old 07-30-2018, 10:11 PM
TxMav's Avatar
TxMav
TxMav is offline
TxMav is gaining momentum as a positive member of FTE.
Miles
2006. I'm at 190,000 miles stock.
Old 07-30-2018, 10:45 PM
bfloyd4445
I was thinking like it came from the factory. Mine is still running perfect but everytime i drive it it scares me because of all the bad things i have read. I use an additive in every tank full with frequent oil changes of 100% synthetic oil. The egr valve bothers me i have never even looked at mine i suppose i should. On another thread there is a guy that claims almost 500k stock original motor but two trannies. I'll likely do as you have one of these days soon just to be safe. I love the old truck
Old 07-30-2018, 10:47 PM
bfloyd4445
Stock? The reason for the question is I believe that the major thing that shortens there life is after market add ons and tuners
Old 07-31-2018, 02:58 AM
Mcrafty1's Avatar
Mcrafty1
Mcrafty1 is offline
Mcrafty1 is gaining momentum as a positive member of FTE.Mcrafty1 is gaining momentum as a positive member of FTE.
149,700 stock everything including the Ford Gold....I do however, drain and fill every 30,000...I don't believe it was ever changed out till I bought it at 103,000 miles though. 7degree spreads on average and that's what it's been for the 5 years that I owned it. Minor mods in my sig, but basically still a stock 6.0
Old 07-31-2018, 07:11 AM
Baatzy
Baatzy is offline
Baatzy is gaining momentum as a positive member of FTE.
Just slightly over 150k. Bought it at just under 125k, paperwork and owners story all lined up of having the turbo replaced around 100k. Otherwise bone stock minus the lift gate he had put on it.
Baatzy
Old 07-31-2018, 07:30 AM
TxMav's Avatar
TxMav
TxMav is offline
Yes, stock. I have switched to ELC coolant with coolant filter and replaced failed FICM with a stock setting FICM from Ed and the alternator and 2 injectors, turbo was replaced by ford by the previous owner. (all maintenance).
To me, stock means, original bolts,oil cooler, egr in tact, no exhaust mods, no tunes, etc. I'm the second owner but I bought it from a ford dealer that the 1st owner bought it from and traded it in to. So they had all the history on it (no mods). Bought it with 92,000 and I've put the last 98,000 miles on it.
I also believe that after market add on can cause more problems than they solve. That said, I would still like to do the egr delete and an Atlas 40 ficm one day.
Old 07-31-2018, 07:40 AM
bismic's Avatar
bismic
bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
If you haven't done them, there are some smart upgrades for the 05-07 model years.
The upgraded dummy plugs and standpipes have proven to be VERY reliable.
The upgraded HPOP discharge fitting (the one-piece fitting that replaces the STC fitting) has been very reliable also. I think the OEM STC fitting is a high priority to get rid of, because if it fails catastrophically, you might crack the rear cover and add a lot of $$'s to the repair.
The blue spring upgrade is another requirement IMO. That said, I think adding on a fuel pressure sensor and gauge is also a requirement. Low fuel pressure will damage injectors - a costly thing if it happens.
The EGR cooler is a weak design. IMO it will fail eventually - even on a stock truck. If you want to jkeep it stock, then I would remove the OEM EGR cooler and install one from BulletProofDiesel.
Personally, I would think that it would be wise to pull the EGR valve every few years to inspect and clean it (and the intake). However, if you do clean it, do NOT use brake clean. Use carb cleaner and make VERY SURE that you don't get the cleaner too high up the shaft or especially NOT up against the solenoid actuator. Always keep the actuator higher than the valve discs so the cleaner won't drizzle into the holes at the bottom of the actuator or pool at the shaft seal.
Lastly, as Baatzy posted - if you still have the Ford Gold, be sure to drain, flush, and refill every 30k miles or so. To be honest, I think the Ford Gold is responsible for many of the 6.0L issues. If you never overheat it, if you never get a pinhole head gasket or EGR cooler leak, if you regularly flush it .................... then you might be OK. That is no way to live because a lot of that is out of your control. The diesel rated (CAT EC-1 rated) coolants have prove to be MUCH better.
Glad you have had success with your truck, but 103k miles sure doesn't represent much wear and tear on it.
Quick Reply: How many miles do you have on your stock 6.0
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
