aftermarket tach
Old 07-25-2018, 04:12 PM
BigDan1's Avatar
BigDan1
BigDan1 is offline
aftermarket tach
1996 7,5L E350 : NO OBDII .....
I want to install an aftermarket tachometer ...wich coil wire gives the proper signal ( W/PK = Ign diagnostic or T/Y = ign coil )
I search all over the forum ,,,,In the old days it was - negative coil side , but on this not sure the coil has 6 wires ....
thanks
Dan
Old 07-27-2018, 01:00 PM
BigDan1's Avatar
BigDan1
BigDan1 is offline
For the sake of others in the future : 96 E350 460 , the Tan/Yellow wire that goes from the coil plug to the ICM is the wire that sends the signal to the tachometer ....did it ,it works !
thanks for nothing ,
Dan
Old 07-30-2018, 05:09 PM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
How big is the tach face and where did you mount it?
Old 07-30-2018, 08:29 PM
BigDan1's Avatar
BigDan1
BigDan1 is offline
2.5" mounted on steering column
Hendrixx
13
01-18-2010 05:54 PM
iamhoss89
01-21-2009 12:56 PM
burninrubber2416
12-23-2008 06:33 AM
wills79
03-08-2005 03:17 PM
MustangGT221
05-24-2004 04:40 PM
Quick Reply: aftermarket tach
