Air Spring System Help
I just had front & rear shocks replaced... along with new air springs in the rear. Mechanic cannot get air springs to re-inflate. He does hear the compressor run.
He did shut the system off (on the message center before starting).
And he did turn it back on after the install.
The compressor does run, so it must be a leak someplace... right?
Seals were not installed on the shocks (huge leak)
Seals were not installed on the shocks (huge leak). So problem found. The mechanic will have to pull it apart and put them in. He could have saved some time with a bit of reading. There were instructions in the replacement airspring cartons, but you know us men. Anyway... not sure if the air suspension error showed up yet. Hopefully not.
IF so... how does one clear the "AIR SUSPENSION ERROR", so the compressor will operate again?
I purchased replacement air bags for my 2007 Expedition EL 4x4, then sent them back when I found a company that sold a complete assembly with new Ford Shocks. Just looked like too many things could go wrong installing those o-rings.
I then had a combine failure of the compressor and solenoid valve on the inlet to the airbag so I decided to swap over to springs. So I have 2 new (less than 5k miles) airbag with shock assemblies up for sale.
With new shocks?
Anyone else has info to add that would be great but if you (davestad) are selling those bags I might be interested depending on what the diagnosis is for my system.
Phil
airbags
thats very fair. i found today that i have a compressor that runs. but is bad and produces no air pressure so i am replacing this tuesday. once i do that i can recheck the system, if i then have issues with bags i would consider buying these. Suncore seems to have very good prices $215 - a $50 core refund, pretty good deal if you need these.
wish me luck !
wish me luck !
jdmak68
1997-2006 Expedition & Navigator
12-14-2007 07:14 PM
