Plasma Cutters
Received 3,090 Likes
on
on
I suggest not buying a transformer based machine. Make sure you get a machine with pilot arc for cutting rust. I suggest looking at the Everlast or Alpha machines. The plasma vulcan from harbor Freight is due out in January but I believe that may end up being a very expensive plasma cutter. You can plasma with a 6 gallon compressor just fine. It's not like air arc gouging with huge cfm requirements.
on
Yes people don't realize that lots of plasma cutters are scratch start. This kills productivity and makes for a terrible experience along with burning up torch consumables. If you are cutting and encounter rust or anything else that causes you to lose the arc you have to start over. With pilot arc you can set the pilot delay which will maintain the arc through most rust and allows you to start in confined areas like you would with a torch. You will find pilot arc in most mid priced machines, I suggest only looking at inverter machines as they are the most versatile in terms of features and flexibility with voltage.
on
Stephen67
17
08-04-2012 11:57 AM
19fifty4
22
12-19-2008 12:30 PM
