Bed load weight question?
Old Jul 23, 2018 | 09:55 AM
kyle j's Avatar
kyle j
Hey fellas have a simple question that just slipped my mind. Yesterday I loaded my 97 f350 4x4 auto reg cabs bed up with concreat and brick and noticed the front upper bump stop on the rear leaf springs were touching the leafs. Honestly was surprised since I didn’t think I had that much product in the bed. Is that a sign I’m maxed out payload wise? Couldn’t remember but thought that’s how you could tell? Cause I have a at least half a bed load left. Thanks in advance. Kyle
Old Jul 23, 2018 | 10:29 AM
farmert's Avatar
farmert
If you are referring to the L shaped brackets that mount to the frame by the front and rear of the springs, they are toe overload brackets. Not really overload, but they come into play to help the lower spring pack when a load is applied. When no load is in the bed, the upper spring does not touch allowing for a little softer ride.
Old Jul 23, 2018 | 10:42 AM
kyle j's Avatar
kyle j
Gotcha thanks for the info. So as long as the trucks not squatting I should be good to throw more masonry in?
Old Jul 23, 2018 | 12:27 PM
oldbird1965's Avatar
oldbird1965
My 5th wheel pin weight is 4,500 and if I didn't have air bags I would be low in the rear.
Old Jul 23, 2018 | 12:50 PM
tasilium's Avatar
tasilium
I have know i have overloaded mine on more than one occasion...suppose its not exactly a wise thing to do....but no one said I was very wise.
Old Jul 24, 2018 | 12:39 AM
Bluediesel250's Avatar
Bluediesel250
If your looking to see how close to "loaded" you are you should be looking at the rubber bump stops that go from the frame to the axle. You'll have to kneel down behind the truck to see it rather than look through the wheel well in most cases. My truck gets run on the overload springs on a regular basis when towing gooseneck trailers
Old Jul 24, 2018 | 07:58 AM
97-psd's Avatar
97-psd
For short local trips I usually let the tires tell me when the truck is fully loaded. For long trips, riding on the overlord is fine but I try to give the bump stops (the ones on the inside that Blue mentioned) plenty of room to move without bottoming out.
NDE
Apr 12, 2018 05:54 PM
mbuchanancherry
Mar 10, 2009 06:44 AM
heavyiron
Oct 1, 2006 08:25 PM
cigarxtc
Sep 16, 2005 07:03 PM
GreatNorthWoods
Jun 1, 2005 10:44 AM
