Engine Sputtering
Old Jul 22, 2018 | 02:27 PM
Gstan's Avatar
Gstan
Engine Sputtering
My '93 300 cid auto was running great when it started sputtering real bad to the point of not being able to make hills. The engine light comes on when it's really bad and goes out when it runs slightly better. I haven't opened the hood yet but I thought I see if anyone had a starting place for me.
I just put in a new alternator the other day but that seems to be OK.
Thanks
Old Jul 22, 2018 | 04:58 PM
evan_nugget's Avatar
evan_nugget
Pull codes and check fuel pressure. If your truck has dual tanks, did you notice if it does this on one tank or on both? Post up what you find, it's a good starting place and can give you more info which will help other, smarter FTE's help you.
Old Jul 22, 2018 | 08:16 PM
Gstan's Avatar
Gstan
What is a good scan tool for pulling codes?
Old Jul 23, 2018 | 08:36 AM
mark1986F150's Avatar
mark1986F150
I use this one:
Amazon Amazon
Check sparkplugs and pull codes
Old Jul 23, 2018 | 11:19 AM
rla2005's Avatar
rla2005
Or you can use a paper clip/jumper wire: Ford Fuel Injection » How To Run a Self-Test
scottddove
19
Nov 17, 2016 08:38 PM
Fordtough25
Oct 26, 2012 01:55 PM
stu37d
1983 - 2012 Ranger & B-Series
Jul 14, 2009 08:05 AM
jroehl
General Automotive Discussion
May 30, 2008 08:30 PM
blrman1962
May 26, 2007 07:15 AM
