Forscan spreadsheet available for 2011-2018 Explorers?
I did a search for "Forscan" in this Explorer forum and found only one thread which was of no help. I've used Forscan to make changes on my 2017 F250 King Ranch and a buddy's 2018 F150 Lariat. My wife just traded in her 2013 2WD Explorer LTD for a 2018 4WD LTD, and I suspect she will want a couple minor changes (disable double-honk & enable secure idle). Is there a spreadsheet available of Explorer-specific Forscan alterations?
Try going into the "as built" section in Forscan. You can "enable" and "disable" most of the features there without worrying about messing up rewriting the codes.
The referenced spreadsheet was posted several years ago and is no longer available. This is a fairly old thread. Any chance someone has a copy of the 2018 Ford Explorer spreadsheet for FORScan and could post it here?
THANKS!
THANKS!
Perfect. Thanks. I was able to open and download a copy of this file. Also got the OE defaults using your VIN link.
Thanks again for providing this data.
Brad
