What MPG do you get when hauling your TC ?
#31
The ride when empty is a little stiff...the 19.5" tires don't flex as much as the E rated ones...this is the sacrifice made but you will appreciate the 19.5" when carrying heavy weight (less flex/role). I did noticed the truck "hunt" ruts in road for the first 500 miles or so rather badly and has been getting better. It is really not bad now and something one gets used to the little it still does it.
To me the biggest sacrifice of the stock 19.5" tires are the lack of off-road/mud/sand capabilities...they are definitely more of a street tire than off-road but this is great for 90-95% if what we do. I have not yet been camping in field and try to leave after a big rain...this does concern me a little for my last dually (2012 F350) I put Toyo 295/20 MTs (and winch) on it and had great off-road capability....good piece of mind if needed. One day I plan to put Warn 16.5k synthetic on truck but have not found a mounting system that is good looking and reasonability priced.
#32
At speeds 65mph or less, I love it. By the way, all trailer tires are only rated for 65mph max; Lance even says 55mph max for truck campers (which I find hard to believe and no one, that I know really follows). So yes above 65mph it does seem geared too low but the F450 is a towing/hauling machine and one should not really exceed 70mph anyway while towing or hauling (my opinion).
If the vast majority of your driving in non-loaded, interstate driving and you like to consistently speed (75mph and greater) then the gearing may bother you.
#33
#34
One thing I was surprised on was how much DEF we used. I filled up at the local truck stop before we left and got the '500 mile' warning in Haines, AK. Approx 2500 miles. Got raped for $28 for 2.5 gals. Got the warning again in BC where it was only $15 CD for 2.5 gals. $11 USD
#36
Point taken, last thing to do is to go see for myself, looking forward to that, thanks for sharing your feedback. I noticed in your original post the front axle weight unloaded quite a bit with camper installed. What do you make of that? Seems like it was a little abnormal to lose that much weight. COG issue?
#37
It's very normal for Lance 1172 (and some other large truck campers) since their center of gravity is rearward of the rear axel. I knew this would happen. I had to weigh the pros and cons of each camper design before making a decision...this was a con for the 1172 but to me the pros made up for it, especially with heavy diesel upfront...still a heavy front end. Also all tires now carry a very equivalent weight. Also gives me room for (one day) for a Warn 16.5k winch.
#41
#42
#44
I'm not one that keeps track of my mileage, never have. We recently returned after a 3000 mile trip around the Southeast.
Adaptive Cruise Control is my new friend, set it at 70, let it do the work. The trip meter says I averaged 10.1, Camper and Cargo Trailer loaded with the Polaris General and all that goes with it. Very satisfied with that. This truck handles the Camper better than any Truck/Camper/Trailer I've ever owned.
