Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
92-96 Bronco 460 swap and dually rear end.
Old 07-20-2018, 09:44 PM
1994FordF-350MegaCab
1994FordF-350MegaCab is offline
1994FordF-350MegaCab is starting off with a positive reputation.
I've got a few questions about 92-96 Broncos, I'm looking to get one as a semi daily driver, what are some things to look for? Another thing I am considering eventually swapping in a dually rear end and fenders (not many of those prowling the streets) and possibly swapping the stock engine to a 460 unless I can find one with it already. How "involved" would the work be? Something I somwhat of a shade tree mechanic or local independent mechanic can handle or would I need a lot of shop experience?
Old 07-22-2018, 08:09 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
Experience as these never came with a 460 or a dana 60/70 rear end. The easy way may be a frame swap?
Old 07-22-2018, 08:55 PM
Finding a 460 in a 1 ton frame would be very good and if the bronco shell bolts up easy (which it probably won't) it'd be a good upgrade. I don't really need the 4x4, until of course I do!
Old 07-22-2018, 09:53 PM
Bubba Jones's Avatar
Bubba Jones
Bubba Jones is offline
Bubba Jones has a very good reputation on FTE.Bubba Jones has a very good reputation on FTE.Bubba Jones has a very good reputation on FTE.
Well I would imagine the 460 would be close to a "direct" swap IF you grab the wiring harnesses from a donor vehicle (engine bay and under dash wiring harness.)
The 7.3 bolted directly in on the passenger side, but the driver's side needed some holes drilled in the frame (only one hole was there). The wiring harness plugged into the existing chassis harness and harness for the rear lights etc. However, I did have to edit some wiring to get things working properly with my existing Bronco wiring. I would imagine swapping a 460 in would about the same amount of work as the 7.3 minus dealing with the fuel system (so less work overall.)
The generic shape of the frame between the F-350 down to Bronco are the same, so fitting a 460 in won't be a problem. You'll just have to figure out what to do with the suspension/transmission and wiring. Swapping in a dually rear end shouldn't be super hard, but making it look good will be a different story. I'm not the most fond of duallys, but if it's something you want, then by all means go ahead!
Old 07-26-2018, 10:33 PM
78Broncoinpieces
78Broncoinpieces is offline
78Broncoinpieces is starting off with a positive reputation.
about that dually....
I'm all for modifying and customizing, it's your truck so do what you want to do etc.
but,,, the extra weight of a dually axle is going to overwhelm the rest of the truck. any pavement that isn't perfect is going to launch the rear of the Bronco.
if it doesn't work out you could always use it as a lawn roller.
jh818
1999 to 2016 Super Duty
06-29-2018 03:24 PM
Dean6586
09-07-2015 07:54 PM
farmert
06-03-2013 11:24 AM
Joshiggity
07-28-2010 07:06 AM
jford99
03-03-2001 11:13 AM
Quick Reply: 92-96 Bronco 460 swap and dually rear end.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
