1978 - 1996 Big Bronco
never had this happen before
Old 07-20-2018, 02:51 PM
Rick Macclymont
Rick Macclymont is offline
Rick Macclymont is starting off with a positive reputation.
my starter is stuck on I had to pull the battery cable to stop it the key is in the off position
Old 07-21-2018, 07:29 AM
schwim's Avatar
schwim
schwim is offline
schwim is starting off with a positive reputation.
The usual cause for that is a failing starter relay.(aka starter senoid). It's located on the passenger fender well near the battery. They are cheap and available at all part stores.
Old 07-23-2018, 10:45 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
And the cheap chinese replacement relays tend to work one time before doing the same thing. Make sure the battery is fully charged and the cables, positive and negative, are in good condition. Clean all of the connections from the battery to the starter (positive) and block (negative). Highly suggest sourcing a USA made starter relay.
Old 07-23-2018, 08:47 PM
ablack350
ablack350 is offline
ablack350 is starting off with a positive reputation.
Fully agree! We see this all the time in classic Mustang world. The new solenoids are junk. I'd rather have a used Ford unit than a brand new reproduction...too many failures!
Old 07-26-2018, 01:19 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
In a pinch you can hit the starter solenoid or the starter to see if it releases when it's stuck. Obviously it's a one time fix to avoid further damage to the starter system.
ozark1
01-03-2018 07:31 AM
kwztoy
1999 to 2016 Super Duty
05-03-2014 08:21 PM
atomicjoe23
08-02-2009 06:50 PM
Mil1ion
18
02-23-2002 12:16 AM
nice59fordf100
08-26-2001 10:22 PM
Quick Reply: never had this happen before
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
