240 6cyc fan and fan shroud.
I'm rebuilding and converting my factory air in my 69 F100 to 134a and I知 looking for recommendations on what size fan w/ clutch to use and I知 also wanting a shroud. Back 20 plus years I took a factory a/c unit off a 72 f100 with a 390 or 360 engine truck that was going to the junk yard. I took everything but the compressor mount which I had to buy one for a 6cyl. and put it on my truck and it worked pretty good best I can remember. I also got the radiator and had to modify my radiator support for it to fit with the factory a/c condenser. The radiator measures 28 across and 20 top to button.
Thanks
Thanks
Thanks
Thanks
I thought Dennis Carpenter sold 300 fan shrouds. But I don't see one on their on-line catalog. I think it hard to find a good used one. If you have a local Pick-N-Pull JY, you might go there and find an electric fan and shroud assembly off some vehicle you can fab up some brackets to mount.
D3TZ-8146-B .. 302 Fan Shroud & D3TZ-8146-C (replaced C8TZ-8146-K) .. 360/390 Fan Shroud.
The D3TZ-C shroud also fits 1965/66 F100 2WD & 1966 F100 4WD like it was made for these trucks, no mods required.
I'd stay far away from those electric fan motors, as they were crap from day one!
