6 volt coil polarity - Ford Truck Enthusiasts Forums
Old 07-16-2018, 08:42 AM
gogoat's Avatar
gogoat
gogoat is offline
gogoat is starting off with a positive reputation.
My question is for 2 other cars that I own. When you change the 6 volt positive ground system to negative ground. Does the coil terminals need reversing also?
Old 07-16-2018, 10:15 AM
fordf11948
fordf11948 is offline
fordf11948 is starting off with a positive reputation.
yes wire from the distributor goes to the neg on the coil
Old 07-16-2018, 06:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I've seen it both ways in previous discussions here and elsewhere. Hard to tell what's right. But look at the internal wiring of a coil (below); seems to me that the primary terminal with both internal windings connected to it needs to be going to the points and more importantly, the condenser. You might do a websearch to be sure.
F151
06-21-2017 08:58 PM
gogoat
08-24-2016 11:29 AM
TyBragg
17
10-25-2013 03:58 PM
jmadsen
08-19-2008 01:44 PM
Tedster9
08-02-2002 04:22 PM
Quick Reply: 6 volt coil polarity
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
