Transmission noise or serpentine belt noise
I have an 05 Ex V10 with the 4R100 trans. Recently I have added a 5 Star SCT X4 tuner and started running an 89 tow tune. The tune makes the truck hold gears a little longer between shifting and seems to have a much crisper feeling shift. Only thing I've noticed now is then when under moderate to heavy acceleration (not towing anything ) I hear what I can best describe as a screeching sound when it shifts from 2nd to 3rd gear. It's very brief and does not happen under light acceleration. I assumed athat first it was a transmission noise but now after some online searching I am seeing that some are saying it's the serpentine belt slipping briefly. It could be as the noise certainly sounds like a belt screech. I can't tell whether it's coming from the engine bay or transmission. It's odd if it's the belt as I have replaced the belt, tensioner and idler pullies maybe 6 months ago. I want to try setting the tune back to stock today to see if it goes away but that won't necessarily tell me if it's the transmission or belt. Has anyone else experienced this?
Thanks,
Matt
Thanks,
Matt
Do this: Got to the parts store or Walmart and get some CRC Belt Conditioner. (Do not get dresser!) Spray it on as directed and see if the noise goes away. If it does go away, recheck the belt and tensioner. With all the crappy Chinese parts anymore, it could be a weak tensioner. if it does not get rid of the noise, start thinking of the bearings in idle pulleys, alternator, and other bearings. I really doubt that it could be the trans under any circumstance.
Maybe, maybe not. I had a new Trans installed on my Excursion in January and in two days I got a massive squeal. People would point as I drove by. The transmission shop said no way... must be breaks. Wasn't breaks... it was coming from the rubber coupling that the drive shaft yoke went through to engage the transmission. I tried to slide the rubber up a bit and smeared a little high temp grease on the shaft and the noise stopped. It did sound like a belt slipping.
I can't imagine anything in the trans squealing, I also think belt slip. When the engine suddenly decelerates because of a quick shift the accessories also have to quickly decelerate. The belt tensioner and belt outing is designed to give max grip in the direction of rotation, when the force is reversed the grip is less.
olderf150
12-13-2013 01:39 PM
68dutchguy
03-26-2010 08:36 PM
txducker
09-07-2004 01:37 PM
