Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Fifth Wheel & Gooseneck RV Towing
Reload this Page >
Interested in F-250 5th wheeling... am I out of my league?
  #46
Old 11-04-2018, 06:16 PM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
KC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to allKC8QVO is a name known to all
Originally Posted by 7591250sd View Post
My 2018 F250SD CCSB, with 6.2 & 4.30 gears pulls our 30' Arctic Fox that empty empty weights are 10.6K & 2100 pin just fine, even double pulling my ATV and trailer..I also have the camper package, sag is about 3 in..
That is a very nice set up, and quite a train going down the road.
I've been curious on the handling of a double trailer set up like that. First off, I looked at some Jayco 5th wheels early in my searching last year and found that they only rate their smaller 5th wheels with a receiver hitch rating of 2000lbs. The bigger 5th wheels have the same hitch it looks like, but the sticker on it says it is not rated for towing - only accessory use like a bike rack. Does Arctic Fox have any ratings for towing on the one you have? Or are you just making do with an accessory-type rated receiver? Or did you add the receiver? Can you tell any difference in handling with the ATV trailer behind compared to without?
  #47
Old 11-04-2018, 08:40 PM
7591250sd's Avatar
7591250sd
7591250sd is offline
7591250sd is starting off with a positive reputation.
The dealer had a local welding/fabrication shop ( Crystal Welding, Rogers MN) weld on a 4" receiver square tube to the frame. They do this often. I've seen no actual ratings for the hitch. I've not noticed any difference double pulling, no sway etc. I'd estimate the trailer & ATV weight to be just under 2k, the trailer is aluminum, and seems very sturdy.
Several buddies in our ATV club double tow with no issues. I do use a rear observation camera.
  #48
Old 11-05-2018, 06:52 AM
Drisean
Drisean is offline
Drisean is starting off with a positive reputation.
Originally Posted by fortheford View Post
We agree, shouldn't exceed payload crudely. Where we probably don't agree is that 10,000 GVWR is *not* a structural design limitation. It is a paper classification. RAWR + FAWR + tire load capacity > artificial sticker to maintain a DOT classification.
To answer this, we would need the construction sheets of an F250 to compare with the ones of an F350. Are the same parts going into both types? If yes, you're right, it's just a nominal thing. If not, then it's dangerous to assume that the cars only differ in their paperwork.
There's two considerations making it hard to determine from the outside. One is that a company likes to manufacture as many similar products on their assembly lines as possible, thus reduce cost. Less variety, less cost. On the other hand, buying less capable items from the supply chain and build them into one type versus another is also saving money. It makes sense that frame and major building parts for F250/350 come from the same assembly line (easy to see from comparing the dimensions), but what happens to components from the OEM may be a different story. Same springs? Shock absorbers? Same rated Tires? And that's where the cookie crumbles.
  #49
Old 11-05-2018, 07:58 AM
fortheford
fortheford is offline
fortheford is starting off with a positive reputation.
This has been done and its on *this* forum...
  #50
Old 11-05-2018, 09:36 AM
scraprat's Avatar
scraprat
scraprat is offline
scraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant future
Yes they have to some degree.
In the end it comes down what the driver of the vehicle feels comfortable with and is it a risk to his or her family that are sitting in the seats of truck while pulling the trailer. We all have our own risk/ reward levels.
https://www.ford-trucks.com/forums/1...ey-begins.html
https://www.ford-trucks.com/forums/1469513-if-f250s-and-f350s-are-the-same-truck-why-does-ford-build-both-2.html#post16851871
e21pilot
Modular V10 (6.8l)
18
05-25-2018 08:50 AM
ct diesel
64
12-28-2015 08:16 PM
52 F-1
Large Truck
06-05-2013 11:35 PM
wyldstallyn73
Kansas Chapter
03-13-2008 09:25 PM
1979F150
Georgia Chapter
03-03-2005 11:34 PM
Quick Reply: Interested in F-250 5th wheeling... am I out of my league?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
