Installed hood, took some time to get it some what aligned not perfect but it will shut. Also received some hub caps, what do you think leave them on or take them off ?
The fronts look pretty good. The rear looks like a chrome wedding cake. I would leave them off, those painted wheels look good as is.
Installed tachometer and finally figured out my timing issues. Very quality Napa reman in Mexico distributor, pickup was colliding with tone ring causing all kinds of problems. Installed old distributor I had at house problems solved.
Purchased some new tires, went with 235/85/16 general grabber atx. I have two sets of general tires on my bronco and daily driver good tire for the money. The best part the tires I received where made in the USA!
Thanks for the compliments just need bed. Have not decided on building a steel bed or purchasing aluminum bed from martins welding.
Cannon is a spud gun made from scrap metal.
