New to FTE
New to FTE
Hello all, new to the FTE. I've been cruising the 2017HD forum for awhile and about three weeks ago I bought a 2018 F-250 XL 6.2. This truck is one of my business trucks and just for my use to rove around jobsites and keep up with the progress. I've been a Ram Cummins customer for around twenty years and my eldest truck ( 1999 2500 5.9 CTD, 497,516 on the OD ) has served me well and overall I have nothing negative to say about the Cummins 5.9 and 6.7 TD. Many of my friends are Ford 250 / 350 owners and other than peripheral issues that occur in all makes, they all really like the Super Duty. I really like this truck and does seem a little strange to pull up to the pump and not use diesel, but I do like the price for 87 as compared to diesel. I do need to ask a recommendation...re; Oil
I've never gone the recommended mileage for the first oil change. I always changed oil and filter in the first 1500 miles and I want to have that done this week but could use some advice on 5w 30 full synthetic brand re; Motorcraft, Mobil 1, Valvoline, Amsoil??
Any thought thoughts or recommendations are greatly appreciated... Thanks, Hal
.....................I do need to ask a recommendation...re; Oil
I did the oil change yesterday 2081 miles and no debris on the drain plug. I have to say tho', I'm not at all impressed with the flimsy corkscrew dipstick that is spot welded 2/3 the way up. All in all, I'm very happy with this truck and as of this morning (doing the math) after fill up I'm @ 15.3 MPG. In my opinion that's pretty good since I spend a lot of time in central L.A. with nothing but stop and go driving. Best to all and have a "Happy and safe 4th!
I've got some advice, but probably not the kind you're looking for ...
I presume you'll change your oil according to the prescribed OEM limits? If so, don't waste your money on syns; for moderate OCIs they will not reduce your wear rates; they won't make your engine "cleaner" and they won't increase your resale value. I have over 200 UOAs on the 6.2L engine, covering 8 years from all kinds of applications and use. I can assure you that syns don't reduce wear in this application, no matter what sales hype or friends tell you. No one ever got an extra $1000 in resale or trade-in because they used Amsoil or Mobil 1.
For a syn lube to be "worth" it's price of admission, it should do something extraordinary that equates to it's price differential. If a syn lube costs 3x more money, then it should do one of two things:
1) reduce wear by that ratio; wear would have to be 3x lower across the board in a normal duration of use
2) extend the OCI by that ratio; wear would have to be "normal" but at 3x the "normal" distance
If the syn cannot do either of those, then you're paying for stuff you're not getting a performance benefit from.
I can assure you, and prove, that in 99.9% of all vehicle applications, syn's don't reduce wear in a "normal" (OEM applied) change interval. And if you're not going to extend your OCI, then you cannot get the duration effect needed. See this link and read the article:
https://www.bobistheoilguy.com/used-...hat-is-normal/
I would know; I'm a reformed syn-lube junkie. I used to think they were the best answer for everything. Then I became educated (due to work opportunities and obligations) and so I got deep into UOAs and equipment PM. I started studying lubricant effects and doing UOAs on all manner of equipment (engines, generators, gear boxes, etc). I put my training in statistical processing/quality control together with my maintenance background. I am not saying this to be a nay-sayer or argue with anyone. I can prove beyond any reasonable doubt that syns lubes are a typical waste of money for normal applications. RARE is the time a syn is NEEDED. Sure, folks "want" to use them. And that's OK. As long as you're OK with wasting your money, that's OK by me. But don't try to convince yourself they are worth the money; the facts and data clearly prove otherwise.
Want a good lube for your 6.2L? Just use any oil that is qualified/licensed under the Ford spec for 5w-30 (WSS-M2C946-A). Sure there are syn lubes that meet the spec. But so do a slew of conventional lubes. Check the PD sheets for conventional Mobil, Valvoline, SOPUS, Castrol and other products.
Thank you Dnewton3 for your informative comments. This new Super Duty is the first truck I've ever used Synth in and I was somewhat torn as to the brand etc and I went with Valvoline full synth. I've always changed oil in my diesels every 4-5000 miles and originally used Castrol and then to Valvoline HD 15w-40. As I mentioned earlier my eldest truck is just under 500,000 on the clock and doesn't burn oil or have any blow by. I know that may be hard to believe, but that's the truth, so if there is any testimony that can be given, "Synth Vs. Dino" I would have to agree that Synth is a waste of $$. I'm curious; how many 6.2 owners have scrapped synthetic?
I might also mention that these are work trucks that are very well maintained but nonetheless worked.
I have often wondered when ford or any manufacturer, recommends an oil, is their intent to get you through warranty or is the recommendation based on a product that will get you many thousands of miles past warranty when changed and used correctly.....
I change my oil every 5k miles. I use 5w30 Mobil 1 full synthetic from Walmart ($22.00 for the 5qt jug) and a motorcraft oil filter also from Walmart ($3). I always buy an extra 5qt jug every other oil change. I change my own oil so that is cheap enough for me, and gives me peace of mind. Oh and I agree the dipstick is ridiculous.
1st oil change was at 3k with Mobil 1 synthetic oil and ford filter. Now I change oil and filter every 5k or a little more maybe 6k. I always use synthetic Mobil 1 5w 20 like the oil cap and manual say and a motorcraft filter. Always buy oil and filter at Walmart. It’s 22 bucks for a 5 quart container and 3 for the filter. So about 35 bucks for a synthetic oil change which is way cheaper than the dealership.
