Is swapping gears worth it? - Ford Truck Enthusiasts Forums
Old 07-13-2018, 07:48 PM
Kyle Wood
Kyle Wood is offline
Kyle Wood is starting off with a positive reputation.
Currently have 3.54 gears in the rear end and im wanting to go to 4.10. Question is, is it worth it. Nearly 1000 dollars for parts (locker, gears,rebuild kit). How much faster will it feel? Is it really noticable? Truck is just for fun so no towing or very little although 4.10s should be good for that either way. Also not a daily, just a toy i drive to work once in awhile. If not 4.10s what ratio should i go with?
Old 07-13-2018, 09:07 PM
Blue and White
Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Gear selection depends (in part) on engine specs and tire size... mostly diameter. What have you got?
Switching from 3.54 to 4.10 will be noticeable. More acceleration, better towing and higher RPM & noise cruising on the highway. Also less gas mileage, I run and like 4.10 with 31" tires. I also tow and do not mind spinning the engine a little to run 70 MPH.
Is it worth it? Up to you. Also worth considering rear ends are a bit tricky and time consuming to work on.
Old 07-13-2018, 10:02 PM
hivoltj's Avatar
hivoltj
hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
9"? I have a used 4.10 Trac lock 3rd member if you are interested. I just swapped the other way; 4.10 to 3.50
Old 07-13-2018, 10:27 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Every penny...unless your driving long distance.
Old 07-14-2018, 12:52 AM
mofoco1
mofoco1 is offline
mofoco1 has a good reputation on FTE.mofoco1 has a good reputation on FTE.
I would be interested if he passes. Splines#?
Old 07-14-2018, 03:56 AM
1TonBasecamp
1TonBasecamp is offline
1TonBasecamp is gaining momentum as a positive member of FTE.
...Nearly 1000 dollars for parts (locker, gears,rebuild kit).
Any reason not in your description that you are wanting a locker? Seems counterproductive (price-wise at least) to put one in. I understand the "might as well, while I'm there" thing, but a locker for your casual and occasional use? Doesn't seem necessary to me.
Anyway, just wondering. But it sure would be less expensive if you do without the locker.
Oh, and yes it's a noticeable difference. But as said, to become a worthwhile difference it depends a lot on what you've got.
After all, it's "only" going to change it 400rpm at 65mph if you have a 31" effective height tire (that's 15.5" from center of hub to ground with the full weight of the truck on it) tires. Doesn't sound like a lot, but you would be surprised.
Good luck.
Paul
Old 07-14-2018, 07:11 AM
scottscott
scottscott is online now
scottscott has a good reputation on FTE.scottscott has a good reputation on FTE.
What is your truck, engine, transmission, 2 or 4 wheel? Hard to advise you without more information.
I will say that if you just want to accelerate quicker, spend the $1000 on the engine for a much bigger bang for your buck.
Old 07-14-2018, 09:04 AM
Kyle Wood
I have a 78 f250 with a mildly built 400 in it, roughly 450 to 500hp accord to dyno simulators. I have 33inch tires, its going to be part time 4wd as of now its rwd. I want the locker because as of now its an open diff and like you said might as well while im there.
also have a dana 60
Old 07-14-2018, 09:34 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
31 spline. It's missing a yoke as I had to rob it for the new 3rd member I built which was missing one.
was running fine when I pulled it this spring, drove for 5 years on it myself
Old 07-14-2018, 10:54 AM
Blue and White
also have a dana 60
You likely have a warm cam in that engine that likes more gear. Also larger tires. I think 4.10 is much better suited to that combo.
Old 07-14-2018, 11:05 AM
Kyle Wood
I take it you meant warn. Why would you think i have a warn cam? My cam is around .560 lift at the valve for both exhaust and intake. I forget the exact specs to be honest
Old 07-14-2018, 11:36 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
F-250 WARHORSE has a good reputation on FTE.F-250 WARHORSE has a good reputation on FTE.
I have 410 gears for front and rear I think I would trade (not sell because that is prohibited here) you for your 354s if they are in similar condition. I understand 60s front and rear?
Old 07-14-2018, 01:14 PM
Kyle Wood
I have a 44 front and 60 rear. Both have 3.54s. Where are you located to trade?
Old 07-14-2018, 05:05 PM
mofoco1
mofoco1 is offline
Let me know Kyle, PM me. Pics if possible.
Old 07-14-2018, 06:40 PM
Blue and White
I did mean "warm" meaning high lift/high overlap. With .560 lift I think so. The engine makes its torque and power at higher RPM vs stock. A higher numerical rear gear ratio will help the truck accelerate better by helping the engine run faster.
Quick Reply: Is swapping gears worth it?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
