P0472 & P2262 after EGR delete
Getting everything running again has been a challenge but it's coming along. Oil leaks are gone, on to the next issue.
P0472 OBD-II Trouble Code: Exhaust Pressure Sensor Low
Suggestions?
- Always on. I wipe the codes and it comes back immediately.
- Comes on first few minutes of drive. Sluggish, can't go over 40. Then turbo kicks in, full power, and when I clear & rescan, the code is not present.
Suggestions?
For some reason my machine doesn't read much. I have the bluetooth obd thing and a PC and ScanXL Professional, but I can't get any more than obd generic, it lists ford engine, ford airbags, ford transmsision, and obd generic, but obd generic is the only one that successfully connects.
It tells me only basic info, rpm, but no speed/gear info, intake and coolant temps, but that's about it.
Get a good light and a 10X magnifier lens and use it inspect the plug for the EBP sensor.
Seporate the wires so you can get a good look at every inch with extra attention the closer to the plug you get.
The little wires get soft insulation over time and exposure to oil and they rub through and short out. You can
set the tool that you have to watch Vref and that should be 5V with little changes. It's a known chafing point.
The fix is a new pigtail plug assembly or you can take it apart and use some very small heat shrink. But it will make
the plug a very crowded fit. If you do the heat shrink repair and even when you do a pigtail repair it is a good idea
to draw a good diagrams on paper with the pin location and wire color for each one. One wire in the wrong lace can
make life a real headache.
Since you don't have any codes for the EGR, you may have a PCM flash that doesn't mind it gone. My truck has a flash like that too.
Have owned the truck for an eternity, everything done was done by me. Chances are I unplugged it when I did the EGR delete and had the intake manifold off, but forgot to plug it back in. I did the delete 5 years ago and then it sat for 5 years, so I'm picking up where I left off.
I'll plug it in when I get home tonight and see what happens.
Originally Posted by JaySVX
Ordered new sensor and tube. They arrived today and I went to install them. Neither fit. The tube was bent the wrong way and the sensor thread was to big in diameter. Did it change at some point?
