Where Does This Green Wire Go? 1986 F150 2WD 302
Can someone tell me where this green wire goes? It seems to be bundled with the EFI harness, but I can't find its mate. It's at the rear of the engine, driver's side. I probably need to replace the wire because the coating is gone and the wire is exposed!
Thanks in advance!
Thanks in advance!
You could follow that green wire back to see if a stripe appears on a less heat affected piece of the wire.
Stripe or dashes could be yellow, light green or white.
The only solid green wire I see in the drawings is the EGR Vent solenoid, but that wire should be over on the passenger fender skirt.
What's that thing'y the green wire is attach to? Plug? Connector?
Page 60 of the 1986 EVTM on Gary's site shows a Dark Green wire (Circuit 360) leading from Pin 33 of the computer to a device called an EGR Vent Solenoid - and you're in the area of the EGR....
Electronic Engine Control - Gary's Garagemahal (the Bullnose bible)
How far back can you trace the green wire from the connector on the valve cover ?
Still no stripe on the wire on the other side of the connector ?
what are the other colors of the wires in the connector, maybe we can find it that way ?
Check the colors on both side of the connector, they may change.....
I suspect that may be Connector; C325
fordtough81
08-22-2013 06:40 PM
roadrash63
06-22-2009 03:16 PM
