Heat/AC Temperature Control
Old 05-26-2018, 09:39 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
2011 F150 Lariat Screw w/Ecoboost - Recently my heat and A/C started running full blast when I turn them on and doesn't seem to respond to the temp setting. Previously, the heat wouldn't blow until the engine warmed up and the fan speed would reduce once the desired temp was reached. Now it seems as though the system (both heat and A/C) are either on or off with no moderation based on the interior temp. Anyone have an idea what I should look at?
Old 07-11-2018, 03:42 PM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
Just wanted to pass along an update for anyone that might be interested. The HVAC blower control module was bad. This is apparently a common problem. Pretty easy to replace, it's in the A/C plenum right behind the glove box.
Old 07-13-2018, 05:31 PM
jchargu3's Avatar
jchargu3
jchargu3 is offline
Easy to replace if you don't have AUTO A/C..
if you have the auto A/C, theres a blend door UNDER the box, that required full removal of my dash. That was a fun day!
Old 07-14-2018, 08:39 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
He has the auto system. You're confusing one of the blend door actuators with the blower speed control module.
ligito
07-28-2015 08:03 AM
cdestuck
2004 - 2008 F150
10-20-2009 08:52 PM
bigtim1985
1983 - 2012 Ranger & B-Series
19
04-09-2007 09:01 PM
MN_Wild
09-24-2003 08:20 AM
nfaulkner
03-18-2003 10:33 PM
Quick Reply: Heat/AC Temperature Control
