95 bronco long cranking before starting - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 07-12-2018, 02:37 AM
widetrackman
widetrackman is offline
widetrackman is starting off with a positive reputation.
Unhappy 95 bronco long cranking before starting
This is driving me bananas. A way back the bronco would crank right-off on a cold start but later after going shopping for 15-30 minutes (hot engine) it would crank and crank before starting. Now it has to crank and crank to get it running on a cold engine. and sometimes it cranks right-up hot or cold. First thing I replaced with a grey ICU, no change, next put in new dizzy, not rebuilt, next checked out fuel pressure regulator it checked ok but will replace for the he-- of it . Once started bronco runs fine ,smooth and no misses. It reminds me of my days with carbs flooding except in this situation I see no smoke or smell of gas. Any ideas?
Old 07-12-2018, 11:11 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Your 1995 Bronco requires a black colored ICM. How did you check the fuel pressure regulator to determine it was okay?
Old 07-12-2018, 08:27 PM
widetrackman
oops I used Black, don't know why I said Grey.
fordtrucksj
Bronco II
10-10-2016 06:04 PM
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
22
04-05-2015 02:52 PM
O43x
02-23-2012 01:50 AM
jetch114
07-10-2008 10:20 PM
Patrick8475
09-05-2003 07:19 PM
Quick Reply: 95 bronco long cranking before starting
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
