MAP reading in TorquePro and Forscan low. Tuning Q?
I know that some tuners change when the engine light comes on due to over boost conditions which removes defueling. As for the TS chip, I don't know that.
Although, something like the OCR from RiffRaff will take care of that issue for you.
OCR - Overboost Code Regulator for Ford 7.3L 99-03
Thank you. I understand all of that. A OCR will not take care of this. The problem is that when the key is on the MAP sensor reads low by around 2psi on 3 different MAP sensors. 14.3 is what it should read for where I live but it only reads 12.3. EBP reads 14.3. Guess I'll have someone remove the chip to see if that is what is causing it. I still want to know if a person who writes tunes can do this? That way I'll know if it is the tune or if the chip is going bad.
I feel stupid that I didn't do this sooner and changed out sensors three times., I went out to the EX and switched through all of the tunes and the and watched what happened in Forscan and it is in the tuning. It is low in 3 of the 5 tunes and matches EBP in 2 tunes. WHy would a person that writes tunes do this?
racinfast002
02-14-2014 01:28 PM
jasonc76
19
10-04-2013 02:30 PM
Shaun lindmark
13
05-04-2010 11:41 AM
