9in rear end swap - Ford Truck Enthusiasts Forums
9in rear end swap
Old 07-11-2018, 09:17 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Pappys53 is gaining momentum as a positive member of FTE.Pappys53 is gaining momentum as a positive member of FTE.
9in rear end swap
I have shock mounts off larger Ford truck to edit the 3 inch axle housing. They will need wider then stock ubolts. That will leave a little space between the ubolts and the leaf springs. Is this going to be a problem? Any suggestions?
Old 07-11-2018, 10:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
How big a gap between the u-bolts and the springs?
Old 07-11-2018, 10:13 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Haven't taken actual measurement but it onnnnnn
Old 07-11-2018, 10:42 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Haven't taken actual measurement but it is not much
Old 07-11-2018, 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I had the same situation, with maybe 1/8" - 1/4" side clearance to the springs. I'm using a GM truck lower plate that is very stout, and I've seen the Ford plates you're using, they are also stout. I've had no problems for 15,000 miles. If you have a newer engine with a lot of HP, may not be as lucky.
Old 07-12-2018, 07:43 AM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Does anyone have pictures of their 9 inch rearend
Old 07-12-2018, 08:32 AM
Hotrod350's Avatar
Hotrod350
Hotrod350 is offline
Hotrod350 is gaining momentum as a positive member of FTE.
Um .... yes but I didn't think this was that type of forum :P
Old 07-12-2018, 10:08 AM
Pappys53's Avatar
Pappys53
Pappys53 is offline
I found pictures showing a plate being used on top of springs that put the ubolts on each side of the springs instead of over the springs. Where can I find the plates or do they need to be made?
Old 07-12-2018, 10:17 AM
Guntown's Avatar
Guntown
Guntown is offline
Craig
Guntown is starting off with a positive reputation.
Check with Barnes 4WD web site they will have what your looking for...
Old 07-12-2018, 11:11 AM
truckeemtnfords
truckeemtnfords is online now
truckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud of
Some pictures of what you are talking about would help a ton. You can weld and re-drill the plates that you have to eliminate the gap if it is a concern but a small gap would not be a problem as long as the bolts are new and properly torqued.
Old 07-12-2018, 11:15 AM
Osubuki's Avatar
Osubuki
Osubuki is offline
Osubuki is starting off with a positive reputation.
Another suggestion - take a look at the Mid Fifty catalog for the 1957-66 parts. They have u bolts and shock mounts that allow you to mount in the stock position under the bed for the 9" that take into account the 3" diameter you are mentioning.
Old 07-12-2018, 01:07 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Not having much luck finding anything on Midfifty's site
Old 07-12-2018, 07:16 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
I found them in their hard copy catalog. Their online web catalog does not have everything
Old 07-12-2018, 09:24 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
I asked a spring maker here in St. Louis this very question. While in the service we use to thave u bolts that were the spring width until they went through the bottom plate Where they widened. They said they couldn’t make that type of u bolt but that there shouldn’t be any problem. I still went to the farm store and bought some small spacers (they look like pieces of pipe) for a trailer and used them to close the space between the u bolts and the springs.
HRracing89
04-12-2011 11:35 AM
Pappys53
05-11-2009 11:35 PM
59'er F100
03-25-2007 10:47 PM
Oregon Bob
11-12-2006 11:22 PM
460FORD
07-31-2002 01:42 PM
Quick Reply: 9in rear end swap
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
