Did Ford's Severe Duty Oil Recommendation Change? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-11-2018, 03:42 PM
Po6ept
Po6ept is offline
Po6ept is starting off with a positive reputation.
I recently took my 2013 F-250 diesel to a local dealership for two towing-related concerns and an oil change. I live in Phoenix, where it's >100 degrees every day.
After getting home, I found they used 10W-30, so I called to inquire. The shop manager told me they use 10W-30 for everything and the new Ford 10W-30 blend is now recommended for all temperature ranges. I called another dealer who said they use 15W-40 in this environment.
My service manual recommends 5W-40 oil for severe duty, including towing and high temperatures.
Has the oil technology changed and did Ford publish new severe-duty oil standards?
Old 07-11-2018, 04:43 PM
Just Strokin
Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
No, not aware of it changing. Most dealer/Quick Lane use what they have regardless of what you ask them to use or the driving conditions. My last oil change at QL was suppose to be with 5w40 full synthetic since it was paid for with a maintenance plan. Got ready to leave and and it said they used 5w30. I had them drain the oil, change the filter and fill with 5w40 since that is what I asked for when they took my "order" for service and the maintenance plan paid covered.
Old 07-11-2018, 05:00 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is online now
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
I personally would go back and have them change it. I have never seen a 10W30 that was rated for Diesel use (not saying there isnít one that is). However in the 12 years of running a diesel truck I have never put anything in it besides 15W40 Dino or 5W40 full synthetic.
Old 07-11-2018, 05:11 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Here's the list of oils which meet Ford's WSSM2C171-F1 specification specifically for the 6.7L, and the almost three pages of approved 10W-30.
File Type: pdf
Old 07-11-2018, 05:34 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
check the max temp range on 10w30
Old 07-11-2018, 06:11 PM
texastech_diesel
Disgruntled Texan
It's unbounded on the top end in the manual for normal usage. I'm not saying I'd use it where the OP is, just that it's the normal usage 6.7L oil and Ford approves its use contrary to an above statement that there are no diesel rated 10W-30 oils.
Old 07-11-2018, 06:32 PM
Po6ept
Po6ept is offline
The service advisor and the service manager tried to convince me the 10W-30 is now recommended severe duty use in a 6.7 diesel, but they couldn't show me where Ford recommends it in writing.
I'm not unhappy. I learned that they either have bad judgement or they can't be trusted - all for the cost of an oil change.
Old 07-11-2018, 07:51 PM
Just Strokin
There are plenty of 10w30 rated diesel oils. 10w30 is oil in the truck when comes from the factory.
Old 07-11-2018, 09:31 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
I would change that oil out for 5w40 syn if it was my truck it even says so right on the oil cap. If you don't fall into the severe duty as outlined in the owner's manual then you should be fine even at those temps.
Old 07-11-2018, 09:59 PM
Benchwrench's Avatar
Benchwrench
Benchwrench is offline
Benchwrench is a name known to allBenchwrench is a name known to allBenchwrench is a name known to allBenchwrench is a name known to allBenchwrench is a name known to allBenchwrench is a name known to all
I find it a bit bizarre that Valvoline has not been mentioned in that list of "diesel" motor oil aside from only two listed as "all-fleet".
Old 07-12-2018, 08:24 AM
texastech_diesel
Disgruntled Texan
The first several iterations of the list were missing all of Shell's Rotella products, probably just hasn't been blessed by Ford yet. Or they're the brand that doesn't have enough phosphorus, which is what Ford is specifically targeting with the standard apparently.
  • Ford recommends oils that meet and are approved against their WSS-M2C171-F1 specification.
  • Ford’s primary recommendation is 10W-30 viscosity grade. (Ford also allows other viscosity grades, as long as they meet WSS-M2C171-F1.)
  • Ford WSS-M2C171-F1 requires an oil to contain between 1,000 ppm and 1,200 ppm phosphorus.
  • This is where the distinction between the “C” category (CK-4) and the “S” category (SN) is important.
  • To meet API SN, an SAE 10W-30 grade oil’s phosphorus level must be below 800 ppm. (This is Ford’s concern.)
  • An oil meeting API CK-4 only in a 10W-30 viscosity can meet the 1,000-1,200 ppm phosphorus levels required by WSS-M2C171-F1; however, it obviously cannot ALSO meet the less-than-800 ppm phosphorus levels required by SN.
  • Remember too that not all CK-4 only SAE 10W-30 heavy-duty engine oils are approved against Ford WSS-M2C171-F1.
  • For instance, Rotella T4 Triple Protection 10W-30, which meets CK-4 only (not SN) and has approximately 1,150 ppm of phosphorus, meets and is approved against Ford WSS-M2C171-F1.
https://noln.net/2017/08/21/clearing...oil-statement/
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
