Camshaft bearing clearance too tight??. Bent?? No spark? timing 180 off??? Ford 300 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-11-2018, 12:28 PM
Jam_econo89
Jam_econo89 is offline
Jam_econo89 is starting off with a positive reputation.
So i had just installed a new crankshaft and alum timing gear for my 4.9l i6. Put the whole thing back together, timed it, then when I went to start it up all it did was crank really slow and then hummed.. About month ago prior to this the old fiber gear shredded on me while driving. I remember not knowing exactly what was wrong and kepped trying to start it up so maybe I might have fried something??. Anyone might have an idea??
Old 07-12-2018, 11:10 AM
Maillemaker
Maillemaker is offline
Maillemaker is starting off with a positive reputation.
Dumb idea, but have you charged your battery? If it's been sitting for a month without running parasitic drain may have run the battery down.
Steve
Old 07-12-2018, 12:09 PM
Jam_econo89
[QUOTE=Maillemaker;18083532]Dumb idea, but have you charged your battery? If it's been sitting for a month without running parasitic drain
yeah.. I had the battery unplugged . It's also not that old.
Old 07-13-2018, 10:14 AM
baddad457
baddad457 is online now
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
A weak battery ? it would stick the starter solenoid open and it would crank until you disconnected the battery or the battery went completely dead.
rbond
09-06-2017 08:54 PM
Rusty_S
08-04-2016 05:37 PM
jeronlines
03-20-2014 06:15 AM
mediaman67
Aerostar
12-23-2005 09:47 PM
LxMan1
08-05-2002 05:09 PM
Quick Reply: Camshaft bearing clearance too tight??. Bent?? No spark? timing 180 off??? Ford 300
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
