4.56 ring and pinion gears? - Ford Truck Enthusiasts Forums
Old 07-11-2018, 12:01 PM
WD Ray
WD Ray is offline
WD Ray is starting off with a positive reputation.
Is there anyone with a 4x2 ,auto trans truck running 4.56 gears ?
Old 07-11-2018, 06:29 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
what is your goal ? Normal gearing would be maybe 3.55 .... to get to 4.56 is a 30% change..... what that is going to do is at 60- MPH when the motor is running 1700 RPM, it will be running 30% faster or 2250 RPM ...... lot more bottom end torque... mileage and top end may be sacrificed.
Old 07-11-2018, 07:45 PM
WD Ray
WD Ray is offline
Yes sir. Thank you for taking the time to reply to my thread. I orig. had a 3.55 gear in my truck,and them swapped out for 4.10. The performance was somewhat different,but now I'm think about going 4.56. Accoording to an RPM calculator it indicates that while at a steady 70 mph with a 4.56 gear my RPMs would be 2503 rpms. Is 2500 RPMS to high for 70mph ?
Old 07-11-2018, 09:48 PM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
What engine?
Old 07-12-2018, 04:20 AM
WD Ray
WD Ray is offline
2000 F150 auto trans 8.8 with a 4.6 V8
Old 07-12-2018, 06:46 AM
00t444e's Avatar
00t444e
4.56 would be good then, that 4.6 needs all the help it can get.
Old-Fart-Al
Ford Truck Parts for Sale
07-06-2016 01:36 AM
TommyLee
32
01-24-2004 12:32 AM
1990F2504X4
01-23-2004 05:43 PM
prerunner
08-24-2003 04:48 PM
pcman
12-23-2001 09:34 PM
Quick Reply: 4.56 ring and pinion gears?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
