6.7L Engine Air Intake Secondary Foam Filter - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-11-2018, 10:26 AM
Batman7777
Batman7777 is online now
Batman7777 is starting off with a positive reputation.
There are a few threads concerning this issue, but I found an article that best explains the use, purpose and location of the Ford 6.7L Secondary (Pre-Filter) Foam air intake filter.
It is a NAPA Article. https://napafilters-z5jsk59bxkjskm52p5f.stackpathdns.com/wp-content/uploads/July-2015-NAPA-500139-HD-Air-Filter-English.pdf
The below pointer works when I put it directly in a browser
https://napafilters-z5jsk59bxkjskm52...er-English.pdf
Parts Place showing the filter
https://www.dieselfiltersonline.com/...es-trucks.html
It appears the foam secondary filter is in place in case the primary filter intake is blocked (i.e. snow). The secondary filter allows air in while the primary is being cleared.
Ford (Local Dealer) Recommends replacing the foam filter when replacing the primary if needed.
Old 07-12-2018, 09:39 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Chuck-B is gaining momentum as a positive member of FTE.Chuck-B is gaining momentum as a positive member of FTE.
I thought the Secondary (Pre-Filter) Foam air intake filter could be washed if not damaged?
Old 07-12-2018, 10:09 AM
Overkill2's Avatar
Overkill2
Overkill2 is offline
Overkill2 is starting off with a positive reputation.
Good info. I completely forgot about mine when I recently changed my air filter. I"ll have to look at it to see if it's in good shape or not.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
