Anyone running a DC Power HD alternator AND Mishi CAC tubes/boots
I was looking at Ficmrepair's alternator offering, and pages for both of the DC Power HD alternators have notes warning about the extra depth of the case that may cause interference with aftermarket CAC tubes and boots.
Of course the XP series doesn't have the extended case issue, but I'm not dropping $650 on an alternator, so any info regarding fitment is appreciated.
Just call them and if they have not tried that setup I bet they may be willing to check it out.
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
I happened to be on the phone today during my drive to Portland OR.
I managed to only spend $0.00 but I now have a place to spend anywhere
from $60ish to over $300ish Aluminum Degas tank is not cheap and the
plastic one I have right now is no longer see through. So I have to pick
which one I want to go with. I should of grabbed the scratched one I had
seen on CL here about 6 months age. The price was nice even with the scratch
in the powder coat. The welding looked sort of half-assed. But I should
of grabbed it. You know the drill. Should Of, Could Of, Would Of, But Didn't.
And now I am the sad one.
Any-who I asked Scott about the setup and he said a small alternator and
large CAC is fine or a Large alternator and small is also fine. The problem is
the very large alternator from DC Power and the large CAC from Mishimoto.
They don't play together at all.
EDIT : You know the ideal thing to do would be to weld in a threaded bung for
a pressure gauge and supply a machanical guage with the second needle that
acts as a high memory pointer as an optional add on. If you don't need or want
it then a threaded plug that is the same color as the tank.
I know everyone here loves Ed and I'm not trying to bash the guy. I spoke to him a few weeks ago and was very impressed with his knowledge of these trucks; something you don't find in very many salespeople. And he is a great salesman, he makes you want to buy everything! My issue is my own, it's to do with a lack of self-control.
I broke down and called. The DC Power HD series alts are a no go with the oversized Mishimoto CAC pipes. I told Ed that I sent an email two days ago and never got a reply and he was apologetic and promised to "shake things up" around the office.
On another note, Ed said he only offers 3 alternators that are compatible with AGM batteries: The Leece Neville, the DC Power 250 amp HD series, and the DC Power 270 amp XP series. IIRC he said the voltage regulators in all the others are set at 14.9v which is too high for AGMs and will cause them to degas. I'm kinda surprised I haven't read anything about that in the plethora of battery threads around here.
Usually does not work that way for me..
Are these common with the Optima batteries or all AGM?
I'm running these: https://www.batteriesplus.com/produc...iesel/sli65agm
This is good info
Thanks
