2006 F250 6.0 - Working Out The Kinks - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 07-16-2018, 09:54 AM
bismic's Avatar
bismic
bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I've never had much luck changing just one battery. Seems like the other was stressed enough to fail in a relatively short time after the first.
FYI - even though a FICM shows 48V, it doesn't guarantee that it is good. As stated earlier, keep a close eye on system voltage.
Don't forget the fuel pressure sensor and gauge. Since you already need a few new injectors, you may have low fuel pressure. If you do, you certainly want that corrected before putting in the new ones.
Old 07-16-2018, 11:40 AM
Don Naslund's Avatar
Don Naslund
Don Naslund is offline
Don Naslund has a good reputation on FTE.Don Naslund has a good reputation on FTE.
Watch a few videos by diesel tech Ron on youtube to learn about your engine. Have your mechanic check the headbolt torque setting when he is in there for the injectors. Sometimes, they are not installed right. Your turbo may need servicing. The collector plate is probably frozen giving you the low pressure. when it is off you might consider installing a billet wheel or similar upgrade.
Old 07-16-2018, 12:35 PM
xcrsp440
xcrsp440 is online now
xcrsp440 is gaining momentum as a positive member of FTE.
Take both batteries in for testing then check the alternator. Ohm out glowplug, diesel tech Ron shows a simple method. Probably end up needing an injector in 7.
Replace the oil cooler. Some green coolants are acceptable have some in mine.
Turbo could be stuck or perhaps the exhaust backpressure sensor and tubing are plugged with soot. Check the codes
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
