motorcraft vs the other brake parts - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-10-2018, 10:45 PM
dustyroad's Avatar
dustyroad
dustyroad is offline
dustyroad is gaining momentum as a positive member of FTE.dustyroad is gaining momentum as a positive member of FTE.
I was trying to bleed the brakes on my 88 E250 when the dreadful slip of the wrench on the bleeder happened.
So I'm anticipating needing the replace the wheel cylinder.
On a popular auto parts website they have motorcraft cylinders for $24 while they have wagner/raybestos/acdelco from around $5
I was going to buy the motorcraft part until I saw the price difference. Where are they made?
The other 3 I mentioned are all reputable but I'd probably choose between wagner and raybestos. I'm not sure where they are made at either.
Probably a safe bet they say china though.
Soaked those dang bleeders a week ago and than again today with kroil and pb blaster and even tried the wax trick..
I'm hoping I can vice grip them off and just replace the bleeder but yea...
Old 07-11-2018, 09:59 AM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
jeffreyclay is starting off with a positive reputation.
Anyone that knows Betty Page and uses Kroil deserves a good wheel cylinder at a good price!
Old 07-11-2018, 10:37 AM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
What kind of wrench did you use ?
Old 07-11-2018, 12:15 PM
dustyroad's Avatar
dustyroad
brake flare wrench
Old 07-11-2018, 12:21 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
When doing a major brake job on my '96 E150 Clubwagon (several years ago) I bought whatever name brand part, other than motorcraft, that was available and they were fine.
One key point: I bought a pair at one store and then had a reason to redo one side a couple of years later and bought a one replacement cylinder. Turns out it had a different bore size which resulted in that wheel locking prematurely. I had to find another cylinder with the correct bore size to match the other size. So check them before installation.
Old 07-11-2018, 02:30 PM
dustyroad's Avatar
dustyroad
Yea I see there are 2 different cylinders available, one with a larger bore for 3" shoes and one for the 2.5" shoes.
I have to remove the drums to see what size I have before I can even order anything.
That was my thought as well on cylinders. I wanted to stick with motorcraft but this isn't a resto and for 20 more each I find it hard to justify for a name.
When any of the ones I mentioned will probably last as long.
Old 07-11-2018, 05:14 PM
baddad457
brake flare wrench
Try a six point socket on it. And if that doesn't work, try one size smaller. If a 3/8" try a metric socket a size smaller like 8 or 9 mm. Hammer it on then use the wrench on it to remove the bleeder.
Old 07-11-2018, 07:33 PM
Wildman25
Wildman25 is offline
Wildman25 is starting off with a positive reputation.
The 3" shoes were mostly used on the duel rear wheels vans with the D70 axle.
Most alternative major brands are fine over the pricey Motorcraft for replacement.
Old 07-12-2018, 10:49 AM
Clubwagon's Avatar
Clubwagon
I have had poor luck with stuck bleeders. I would just replace the cylinders and be done with it. If the bleeders are that stuck then the cylinder bores are likely pitted and the seals hardened and should be replaced anyway.
Old 07-12-2018, 03:20 PM
fordman75
fordman75 is online now
fordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to behold
I prefer to stick with Motorcraft parts. I've ran the cheap parts too. I've also had to replace wheel cylinders that I recently replaced because they started leaking.
But just because it's Motorcraft doesn't mean it's great parts either. I spent more and bought Motorcraft brake drums for the back of my 96 E250. Well when they showed up it said "made in china" on the boxes. I was not real happy.
So it's really a coin toss either way. Parts quality can be crap no matter what name is on the box.
I try to stick with Motorcraft parts for starters, water pumps, calipers, thermostats, etc.
F2502011
6.7L Power Stroke Diesel
12-28-2012 10:26 PM
1_ton_bronco
WTB - Parts & other
09-03-2012 06:53 PM
ErrorS
17
06-20-2007 07:33 PM
Daviddc114
1997-2006 Expedition & Navigator
10-18-2006 08:33 AM
hotwheel_2000
Ranger & B-Series
13
01-31-2006 05:16 PM
Quick Reply: motorcraft vs the other brake parts
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
