1986 6.9 engine drop into a 1987 f250 zf5 4x4 transmission - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
Old 07-10-2018, 09:36 PM
Patriot IDD
Patriot IDD is offline
Patriot IDD is starting off with a positive reputation.
Hi, I have a few questions hopefully someone can help me with. So I have a 1987 6.9 f-250 4x4 zf5 transmission with a bad 6.9 engine. I know a guy with a 1986 6.9 f-250 2wd c6 transmission and ATS Turbo. If I pull the 1986 engine and drop it in my 1987 will it fit right in with no modification? I know if I want to put a turbo on it I will have to do some modification to make it fit. But my main concern right now is the 1986 6.9 engine going into my 1987 f-250 5speed manual fine.
Thank you to everyone in advance.
Jake
Old 07-10-2018, 11:11 PM
Etone
Etone is offline
Etone is starting off with a positive reputation.
its plug & play. you will need single mass flywheel clutch conversion kit for 7.3 idi. Luk #07225 flywheel/clutch kit is what I used iirc.
Old 07-11-2018, 01:07 AM
Patriot IDD
Sweet! Does a company make the kit? Also can I still use the late still glow plug relay on the 1986 6.9 engine? I don't see why I wouldn't be able to but I know the 1986 had the old style relay. Just want to make sure. This is my first time getting this indepth with a vehicle.
Old 07-11-2018, 01:19 AM
Patriot IDD
Sorry should has asked what company sells the kit online? Like rock auto etc.. I looked and I say a few but different part# than what you gave me. I just want to make sure I buy the right part.
Thank you.
Old 07-12-2018, 05:30 AM
cadunkle's Avatar
cadunkle
cadunkle is offline
cadunkle has a good reputation on FTE.cadunkle has a good reputation on FTE.
I got mine from Rock Auto. Luk 07-255. I've used it on 6.9 and 7.3. Supposedly 6.9 is a very slightly different imbalance, but I noticed no vibrations or oddities.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
