Best way to lift a crewcab off?
Hello everybody, I’m in the process of stripping down my 1979 F350 crew cab and was wondering what’s the best way to lift a stripped down cab off the frame. I have a skid steer so I was thinking of running straps through each door opening and lifting that way. Will this cause damage? I’ve seen it done with regular cabs before. What does everybody think? Thanks in advance.
I would not run straps thru the doors and lift unless you use spreader bars.
If you were to lift the straps will pull to the center lifting point and could crush the door opening / drip rails.
Straps thru the doors and 4x4's thru the 2 straps. Maybe 4x4's between the 2 4x4's as spreaders thru the straps. You can then lift from the 2 added 4x4's.
This way it is lifting up at the doors and not up & in (crushing) the doors openings.
Now the best way ....... Get a lot of people to lift it off then give them pizza & beer!
On my regular cab I was able to do it by myself. I jacked the truck up then lifted 1 side up a little, kick a saw horse under the rocker then lifted the other said and did the same.
I then pulled the rear axle, lowered the rest of the truck, put the rear of the frame on dolly and rolled the frame out from under the cab.
Dave ----
Dave ----
Dave ----
Dave ----
J: It might be overkill, but I would put 2x10 or 2x12 planks across through the door openings, with some 2x4 blocks screwed into them on the inside & outside to keep the wide ones from slipping, then put your straps around the plank.
Another local fellow here is working on a '68 Crew (going on an '03 F250 SD chassis), but he has a four post hoist, so lifting the body is EASY for him
James
James
If they go from the ends of the 2x6 to a center life point they can still crush the cab.
I was thinking what you mad but on the top.
Run the straps thru the cab from wood end to wood end.
Then make a central lift point on the wood frame.
Dave - - - -
Not to break in but those saw horses look like plastic ones from Homedepot is that correct. I have several pairs of those and I have a 69 F100 single cab and I like the idea of lifting the cab with my floor jack and setting it on saw horses and pulling the frame out from under the cab. I even have several pairs of those heavy duty jack stands too. That to me would be easer that all that strap and building a spreader and then finding some where to hang my come along to pull the cab. I don't have any type of heavy equipment other than my zero turn lawn mower.
Strap from the board down into right front door to the left front door up to the board. Do the same for the rear door.
Then all you would need is to make a central lift point on the wood frame.
Just thought of something I did for the bed. My garage has open rafters and I was able to put straps over the rafters and hang down to the lifting points on the bed.
If you had something like this then you could use that wood frame inside and longer boards and using 4 straps lift at each board end.
Other wise if you lift with out the spreader frame it will pull to the center on each strap and this may not be a good thing.
Dave ----
kramttocs
17
03-25-2016 07:39 AM
TheBlueMule
03-22-2016 09:55 PM
ulev1st
10-11-2013 06:39 PM
FarmerBill
23
09-01-2010 04:20 PM
