GP fusible links burned up. Can I use inline fuses in a pinch?
Old 07-13-2018, 11:15 AM
big ole ford's Avatar
big ole ford
big ole ford is offline
These are the ones i have used in the past.
Old 07-13-2018, 11:21 AM
The_Josh_Bear's Avatar
The_Josh_Bear
The_Josh_Bear is offline
So to eat even more crow than my bad math earlier, I opened my hood up today and realized that the circuit I had the 15a fuse in wasnt even the GP circuit. Obviously I haven't paid it much attention...
And curiosity got me going so I hooked up my 100A ammeter clamp to one wire feeding the GP's and under 3 seconds of "on" timeit said OL for overload. So well over 200A for both wires together for certain, at least to start the day at 70* ambient.
Old 07-13-2018, 11:22 AM
big ole ford
These are the breakers I have used before, but if you use a fuse a 200 amp would be better. I have seen many people use the AMG type fuses in the 200 amp with no issues. I just prefer the breaker because if it trips you just reset it but if the fuse blows you got to get the idiot's at the parts counter to find you another one with out the computer and a a specific application
Old 07-16-2018, 06:39 PM
genscripter's Avatar
genscripter
genscripter is offline
I found out where the wires after shorting out. Up by the engine harness connector, the wire rubbed against the metal ac lines. It was sparking when I was pulling my oil dipstick. Fixed it with insulation and electrical tape. Then put in new fusible wire near the solenoid.
Old 07-16-2018, 10:06 PM
The_Josh_Bear
Sweet, glad to hear you're good to go!
Sycostang67
09-20-2009 12:09 PM
ntputter17
03-14-2009 10:56 PM
greenterror
08-07-2008 06:28 AM
kms910
1997-2006 Expedition & Navigator
05-27-2004 02:56 AM
wgr
Electrical Systems/Wiring
20
05-09-2004 10:45 PM
Quick Reply: GP fusible links burned up. Can I use inline fuses in a pinch?
