Did Ford's Severe Duty Oil Recommendation Change?
I recently took my 2013 F-250 diesel to a local dealership for two towing-related concerns and an oil change. I live in Phoenix, where it's >100 degrees every day.
After getting home, I found they used 10W-30, so I called to inquire. The shop manager told me they use 10W-30 for everything and the new Ford 10W-30 blend is now recommended for all temperature ranges. I called another dealer who said they use 15W-40 in this environment.
My service manual recommends 5W-40 oil for severe duty, including towing and high temperatures.
Has the oil technology changed and did Ford publish new severe-duty oil standards?
No, not aware of it changing. Most dealer/Quick Lane use what they have regardless of what you ask them to use or the driving conditions. My last oil change at QL was suppose to be with 5w40 full synthetic since it was paid for with a maintenance plan. Got ready to leave and and it said they used 5w30. I had them drain the oil, change the filter and fill with 5w40 since that is what I asked for when they took my "order" for service and the maintenance plan paid covered.
The service advisor and the service manager tried to convince me the 10W-30 is now recommended severe duty use in a 6.7 diesel, but they couldn't show me where Ford recommends it in writing.
I'm not unhappy. I learned that they either have bad judgement or they can't be trusted - all for the cost of an oil change.
I personally would go back and have them change it. I have never seen a 10W30 that was rated for Diesel use (not saying there isn’t one that is). However in the 12 years of running a diesel truck I have never put anything in it besides 15W40 Dino or 5W40 full synthetic.
The first several iterations of the list were missing all of Shell's Rotella products, probably just hasn't been blessed by Ford yet. Or they're the brand that doesn't have enough phosphorus, which is what Ford is specifically targeting with the standard apparently.
https://noln.net/2017/08/21/clearing...oil-statement/
- Ford recommends oils that meet and are approved against their WSS-M2C171-F1 specification.
- Ford’s primary recommendation is 10W-30 viscosity grade. (Ford also allows other viscosity grades, as long as they meet WSS-M2C171-F1.)
- Ford WSS-M2C171-F1 requires an oil to contain between 1,000 ppm and 1,200 ppm phosphorus.
- This is where the distinction between the “C” category (CK-4) and the “S” category (SN) is important.
- To meet API SN, an SAE 10W-30 grade oil’s phosphorus level must be below 800 ppm. (This is Ford’s concern.)
- An oil meeting API CK-4 only in a 10W-30 viscosity can meet the 1,000-1,200 ppm phosphorus levels required by WSS-M2C171-F1; however, it obviously cannot ALSO meet the less-than-800 ppm phosphorus levels required by SN.
- Remember too that not all CK-4 only SAE 10W-30 heavy-duty engine oils are approved against Ford WSS-M2C171-F1.
- For instance, Rotella T4 Triple Protection 10W-30, which meets CK-4 only (not SN) and has approximately 1,150 ppm of phosphorus, meets and is approved against Ford WSS-M2C171-F1.
