Speedometer app on my phone - Ford Truck Enthusiasts Forums
Old 07-09-2018, 09:19 PM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
A while back someone posted a thread about a speedometer app on his phone. My son helped me find it and download it to my phone.
I knew the speedometers on my truck were not accurate with my 54 being way off.
Here's what I found. My 55 speedo is 3 to 5 mph fast. The faster I go the more it is off. So if my speedo says 60 I'm really doing 55mph and thats maxing out for my F350 with a 5.83 rear end.
The speedo in my 54 is 5 to 9 mph too fast. Like 5 mph off at 30mph and 9 mph off at 70. So if my speedo says 70 I'm actually doing 61mph. And that's about as fast as I go.
I was going to take a picture for you guys but suddenly realized I can't take a picture with my phone when it's lying on the dash!
Old 07-09-2018, 09:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I have observed the same non-linear behavior on my '52's speedo. 10% low up to about 50 (which is to be expected with the 3.50 gears that are 10% lower), then it increases to 15% at 65.
Are you using Ulysse app?
Old 07-09-2018, 10:01 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
bobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant future
Yes, when speedo is off its a non linear error.
I use a speedo app now and again, typically for a few miles out on a road trip, the rest of the time I just wing it.
My speedo is off about 4MPH at 70MPH.
Bobby
Old 07-09-2018, 10:02 PM
abe's Avatar
abe
abe is online now
No, it is called Cool Niks, I think.
Old 07-09-2018, 10:10 PM
abe's Avatar
abe
abe is online now
Why would my 54 speedo be so off? I haven't changed the rear end. I have stock size tires (6.00) on 16 inch wheels. I ​​​​​​think i replaced the speedo head back in 1999. I know I replaced the odometer but am not sure if I cleaned up the speedo and put it back in the instrument panel or if I cleaned up one from a junk yard. But that shouldn't matter, right?
Old 07-09-2018, 10:58 PM
Harrier's Avatar
Harrier
Harrier is offline
Harrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant future
My speedometer seemed fairly accurate, but it bounces a bit, so getting exact is not easy. I need to lube the cable.
I have an app for my iphone named Speed Box. I could't find the two you guys mentioned.
I think I downloaded a couple of different ones. They are handy for double checking your speedometer. I used it in my daily driver to see how accurate the app was. (assuming my dd speedometer is accurate)
Old 07-10-2018, 05:59 AM
Badmoonreizen's Avatar
Badmoonreizen
Badmoonreizen is offline
Badmoonreizen is gaining momentum as a positive member of FTE.Badmoonreizen is gaining momentum as a positive member of FTE.
I use Speed Box, downloaded from the Apple app store. Excellent free app. A company that advertises in Street Scene sells a small gear box which connects to the speedo cable and the trans which corrects any error.
Regards, Mark.
Old 07-10-2018, 08:03 AM
Mr. Ed
Mr. Ed is offline
Mr. Ed has a good reputation on FTE.Mr. Ed has a good reputation on FTE.
A 5:83 rear? What are you doing, drag racing?
Later!
Mr. Ed
Old 07-10-2018, 09:58 AM
MIKEDEL
MIKEDEL is offline
MIKEDEL is starting off with a positive reputation.
My 54 which is all original also reads about 10% higher than actual speed.
Old 07-10-2018, 12:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Badmoonreizen View Post
....A company that advertises in Street Scene sells a small gear box which connects to the speedo cable and the trans which corrects any error.
Regards, Mark.
Do you have a name for that company? The places I've seen those sell a unit for like $150, apparently milled out of gold bars.
Old 07-10-2018, 01:01 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
Joe and Mark just downloaded Speed Box from the Apple App Store. It’s a tourqouis square box with a white diamond inside. It’s a game.
Nevermind I think I found it. It’s called Speedometer Speed Box App by Hans Schneider basic is free Pro is $3.99
Old 07-10-2018, 01:34 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
I just downloaded one called just plain “Speedometer” for my iPhone yesterday. Free. Easy to read. Worked fine on my test drive yesterday.
Old 07-10-2018, 01:50 PM
raytasch's Avatar
raytasch
raytasch is online now
Old guy with old toys
raytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputation
These old mechanical speedometers were notorious for being inaccurate. In days of old, the auto testers sometimes used a fifth wheel speedometer and reported the inaccuracies.
Old 07-10-2018, 08:21 PM
abe's Avatar
abe
abe is online now
Later!
Mr. Ed
Hardley! The standard rear in a 55 F350 was a 5.18. For some reason the original owner ordered the truck or bought it off the lot with the optional 5.83 rear. They owned an orchard, to perhaps they used it to pull stumps.
Old 07-11-2018, 06:23 PM
CBeav's Avatar
CBeav
CBeav is offline
CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.
The days are long gone when most large cities had several speedo shops. A spinning drum with magnets magically tugging at another drum (or cross bar) inside it, tensioned by a watch spring, didn't make for great accuracy in a high volume production part. Your readings fall about right in the middle of expected error/tolerance for the time. Also, don't discount the possibility of GPS 'tolerance' also. Plus, your phone isn't a dedicated GPS device, there's a lot of other things that could be sucking up CPU cycles at any time while you're GPSing and cause minor inaccuracies. If you want another source for verification try doing 45 through a a school zone once school re-opens. ;-)
Quick Reply: Speedometer app on my phone
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
