Speedometer app on my phone
A while back someone posted a thread about a speedometer app on his phone. My son helped me find it and download it to my phone.
I knew the speedometers on my truck were not accurate with my 54 being way off.
Here's what I found. My 55 speedo is 3 to 5 mph fast. The faster I go the more it is off. So if my speedo says 60 I'm really doing 55mph and thats maxing out for my F350 with a 5.83 rear end.
The speedo in my 54 is 5 to 9 mph too fast. Like 5 mph off at 30mph and 9 mph off at 70. So if my speedo says 70 I'm actually doing 61mph. And that's about as fast as I go.
I was going to take a picture for you guys but suddenly realized I can't take a picture with my phone when it's lying on the dash!
Why would my 54 speedo be so off? I haven't changed the rear end. I have stock size tires (6.00) on 16 inch wheels. I think i replaced the speedo head back in 1999. I know I replaced the odometer but am not sure if I cleaned up the speedo and put it back in the instrument panel or if I cleaned up one from a junk yard. But that shouldn't matter, right?
My speedometer seemed fairly accurate, but it bounces a bit, so getting exact is not easy. I need to lube the cable.
I have an app for my iphone named Speed Box. I could't find the two you guys mentioned.
I think I downloaded a couple of different ones. They are handy for double checking your speedometer. I used it in my daily driver to see how accurate the app was. (assuming my dd speedometer is accurate)
Joe and Mark just downloaded Speed Box from the Apple App Store. It’s a tourqouis square box with a white diamond inside. It’s a game.
Nevermind I think I found it. It’s called Speedometer Speed Box App by Hans Schneider basic is free Pro is $3.99
Hardley! The standard rear in a 55 F350 was a 5.18. For some reason the original owner ordered the truck or bought it off the lot with the optional 5.83 rear. They owned an orchard, to perhaps they used it to pull stumps.
The days are long gone when most large cities had several speedo shops. A spinning drum with magnets magically tugging at another drum (or cross bar) inside it, tensioned by a watch spring, didn't make for great accuracy in a high volume production part. Your readings fall about right in the middle of expected error/tolerance for the time. Also, don't discount the possibility of GPS 'tolerance' also. Plus, your phone isn't a dedicated GPS device, there's a lot of other things that could be sucking up CPU cycles at any time while you're GPSing and cause minor inaccuracies. If you want another source for verification try doing 45 through a a school zone once school re-opens. ;-)
