Mods That Didn't Live Up To Expectations
Hilarious! Reps sent.
Very true. Some of the price is tied up in making his stuff legal for us in CA. While there are better cost-effective ways to get more (and who doesn't want that), paying the "premium" allows some of us to not require removal and re-installation of said parts every 2 years. Outside of that you generally get less for more from them regarding 7.3L "upgrades".
Damn, thought I was the only one. Have had to replace the o-rings on it twice. It was giving the same headache as the filter housing drain valve....... Too bad we lost one of the original plugs, or it would have been removed completely.
Stewart
I guess I’ll add mine, the dual pyro and dual fuel pressure gauge set up, perhaps it is how the install was done, not entirely sure, clay thinks it may be a grounding issue, had the install diagnosed at the place that did it, and they say two sending unit are bad…was supposed to be a quick install of my isspro v2’s guess I need to talk to isspro as well…I dread doing so
I understood the HID craze - it's new and it's bright. I know they can be brighter, but it's a lot of expense and hardship when waiting for LEDs or just buying a brighter bulb would have sufficed. I look at HID like I look at CFLs - it's just an interim technology between incandescent and LED.
I actually like them, the color emitted, I had great visibility.
But, coming back from a trip to SD somewhere near St Louis the light went out (we usually pull an "all-nighter" driving from SD to GA) and then the other side went out at dusk. On the vast rural interstate we could have made it on Hi-beams, but what the heck take another half day to come back, in safety. Time to pull over and find a campground.
The way they were set up you couldn't just go the Irish parts store and buy a bulb.
An aftermarket max A/C assist that failed from day one. Tech support told me it was a weak vacuum pump despite vent changes working fine and ESOF working fine. Turns out that the valve would not close all the way and the A/C was producing ever so slightly cooler air.
I removed it, smashed it with a large 3 pound hammer and laughed. The POS part smashing somewhat flat to the concrete driveway were the best results I had seen from that device since I overpaid for it.
I have since installed the Ranger/Excursion Ford valve (not leaking, knock on wood) and the A/C is blowing much cooler air. Should have just done that from the start. If the Ford valve does fail, I will try again and if that one fails, I will install a manual ball valve.
#28
#29
#30
I haven't read this entire thread so it may have already been mentioned. I think the CCV (Crank Case Vent) mod that people do is rediculous. To me it serves no purpose and only adds smell and smoke. The amount of oil vapors and mist that enters the intercooler is miniscule. JMHO
