1967 Econoline Headlamps -- Need Help - Ford Truck Enthusiasts Forums
Old 07-08-2018, 07:30 PM
Sam's1967
Sam's1967 is offline
Sam's1967 is gaining momentum as a positive member of FTE.
Hi guys. I pulled these headlamp buckets and trim rings from a 1967 Ford Econoline. Are they OEM? Also, were they the same for all 1st generation vans? Or used in 2nd generation vans?
Thanks
Old 07-10-2018, 10:00 AM
Sam's1967
If anyone has a Ford sketch of a 67 lamp that would also help. The wiring has a C1 number on same.
Old 07-12-2018, 10:48 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Headlamp buckets (C1DZ-13118-A) are the same: 1961/66 F100/1100; 1961/67 E100; 1961/70 Falcon, 1966/69 Bronco.
Upper pic:
Old 07-12-2018, 03:14 PM
Sam's1967
Upper pic:
Thanks ND. The diagram helps a lot. Was the metal housing just used on Econolines or were they used on trucks as well? I can't ever recall seeing any on trucks. I am referring to 13021, I guess.
Old 07-13-2018, 11:10 AM
tody
tody is offline
tody is starting off with a positive reputation.
from what i remember restoring my 67 econoline, these are van specific buckets.
Old 07-13-2018, 08:31 PM
NumberDummy
Uh huh...
If you bought the right & left headlamp assemblies, they were C1UZ-13008-A Left & C1UZ-13008-B Right because they came with multiple parts, several of which were Econoline only, but...
This did not include the buckets, seal beams, retaining rings.
See 13008 in pic in post #2.
Old 07-15-2018, 07:24 PM
Sam's1967
I came across some assemblies from a 1962 Falcon and the housing appear to be at least similar to that of the Econoline. There are some distinct differences such as the tabs that are used to mount the headlamp doors and possibly the grille. I would bet dollars to donuts that in a pinch, you would be able to use the Falcon housings and remove the extra tabs if you needed some for your Econoline. Here are some pics of the 1962 Falcon assemblies -- side by side comparison that were removed from the 1967 Econoline.
The one on the top is from the Econoline and the bottom one is from the Falcon
The top one is from the Falcon and the bottom is from the Econoline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
