Help Identifying and servicing this rear axle - Ford Truck Enthusiasts Forums
Old 07-08-2018, 06:55 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
bmoran4 is gaining momentum as a positive member of FTE.
I was hoping to service my rear axle and see if seals were available. First step is identifying this single speed rear axle and locating the fill plug & level, and finding service documents.
Old 07-09-2018, 08:28 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
I'm guessing it has to be one of the F6 single speed ones mentioned here, but haven't been able to connect the dots. Any help appreciated!
Old 07-09-2018, 08:41 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Comparing your photos with the descriptions in the service manual, it appears your axle is the one described starting on page 168 of your service manual, Split Housing Hypoid Rear Axle for F6 and F7 trucks. All of the 8TH axles would be the same except for the gear ratio. I can't read your stampings, but somewhere in those numbers may be the ring and pinion tooth count. The axle ratio may also be stamped on the glove box tag, if so equipped.
Old 07-09-2018, 08:43 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is online now
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
That axle will be one of the three listed for an F6; 8TH-4209-A, 8TH-4209-B, or 8TH-4209-C, depending on the ratio. It is a split housing Timken hypoid axle. The F5 and smaller trucks had Timken spiral bevel axles. The wheel seals are the same in the F4-F6 axles, single speed and two speed. I have the number for those in the shop and I can post that tomorrow. I don't have a number for the pinion seal, but I can cross reference it to a modern replacement if someone can post the Ford number.
Mark
Old 07-09-2018, 08:49 PM
52 Merc's Avatar
52 Merc
Mark
Pinion grease seal, 50-55 F6 with single or 2 speed rear axles, 8T-4676-B
Old 07-09-2018, 09:05 PM
49fordv8f4's Avatar
49fordv8f4
Thanks, Wayne. That is the same seal I just installed in my two speed, and I have the crossover for that. I will post them tomorrow.
Mark
Old 07-09-2018, 09:56 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
Thanks all! I think I am in agreement that it is the Split Housing Hypoid Rear Axle. Unfortunately, I find the shop manual frustrating. The section starting on pg 168 mentions nothing about any gear oil (except to lubricate seals and bearings before installation). The exploded diagram dosen't even show a drain plug at the bottom.
Old 07-09-2018, 11:45 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
That axle will be one of the three listed for an F6; 8TH-4209-A (7.20-1), 8TH-4209-B (6.20-1), or 8TH-4209-C (6.80-1), depending on the ratio. It is a split housing Timken hypoid axle.
These are the part numbers for the ring and pinion kits for the Timken model E155 single speed rear axle.
BB-1175-C .. Rear Wheel Grease Seal - 4.56" O.D. / Timken # A-1205-P-276 / Obsolete
1948/52 F4/F5/F6; F5/F6 COE; F5 Parcel Delivery.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 5 = 800-476-9653.
8T-4675-B (replaced 8T-4675) .. Pinion Seal - Timken E155 / Eaton # 12650 / Obsolete
No Ford dealer or obsolete parts vendor has any.
Pic: Rear Axle Application Chart .. JH = F5 Parcel Delivery; TL = F4; T = F5; TH = F6; W = F5 COE; WH = F6 COE
Old 07-10-2018, 11:00 AM
49fordv8f4's Avatar
49fordv8f4
Here are the crossover numbers for the seals you need. The 8T-4676-B pinion seal crosses to National 410737 and C/R 22425. The hub seals BB-1175-C crosses to National 5751 and C/R 31288. I used both National seals, the 410737 pinion seal and 5751 hub seals, on my two speed axle. The 5751 National hub seal has the deep flange out the back of the seal and is leather like the original seals. The C/R hub seal is rubber, but if I remember correctly it doesn't have the flange. The flange is to help direct any oil that may leak past the seal into the cone on the backing plate and out the weep hole in the backing plate. These seals are available at most any parts store.
Mark
Also, in case you are not aware, there is a large snap ring retaining the seal in the hub. Usually they are covered in old oil and dirt and are not seen.
Old 07-10-2018, 11:07 AM
bmoran4's Avatar
bmoran4
bmoran4 is offline
Thanks for the seal part numbers and such! I'll have to think about if I want to replace all the seals and such. I think first, I'd like to top off the gear oil and monitor how much it leaks. I presume 80W90 would work? I Still haven't located a fill location or an appropriate fill level. (On my F5, there was an obvious fill plug and you filled it on level ground until it started to leak out the fill plug.)
Old 07-10-2018, 05:56 PM
49fordv8f4's Avatar
49fordv8f4
Isn't the big hex nut protruding from the side of the case by the pinion in your 1st photo the fill/level plug? Your axle would have had either 90W or 140W in it originally. I would top it off with one of those. If you were to do a flush and refill, you could use a multi weight gear oil, but you would want to make sure that it is yellow metals safe. There are bronze thrust washers on the differential side gears. If I understand correctly, if the oil has an MT-1 rating along with GL-5 or GL-6 rating, it is rated for manual transmissions, therefore yellow metals safe. I just flushed and refilled the Eaton two speed I installed in my F4. I used Mystic 85/140W gear oil that has the MT-1 and GL-6 ratings. The Eaton axle has bronze thrust washers in it also.
Mark
Old 07-10-2018, 06:03 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
That big hex nut seems way to low...
Old 07-10-2018, 06:23 PM
49fordv8f4's Avatar
49fordv8f4
It looks like it is at about the same level as the plug on my Eaton axle.
Mark
Old 07-10-2018, 06:50 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
Well, I guess I'll try to find yellow safe gear oil and top her off through the hex nut.
Seems to be some contaversey if GL-5 is yellow metal safe.
Old 07-10-2018, 08:03 PM
49fordv8f4's Avatar
49fordv8f4
140W gear oil is available at many parts stores. It is yellow metal safe. As far as I understand, GL-5 and GL-6 gear oils are yellow metal safe if they also have the MT-1 rating.
Mark
Quick Reply: Help Identifying and servicing this rear axle
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
