OBDI code 67 - Park/Neutral circuit fault PNP? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-08-2018, 03:02 PM
Maillemaker
Maillemaker is offline
Maillemaker is starting off with a positive reputation.
OK, I finally found my EEC Test connection (it was on the passenger side, not driver side) on my 1990 E350 with 460 engine.
Ran my jumper, got up to temp, and the good news is I'm getting a Code 11 with key on, engine on, which means System OK.
However, with Key On Engine Off, I'm getting a stored code of 67, which is said to be Park/Neutral circuit fault PNP.
What is this?
Steve
Old 07-08-2018, 04:13 PM
annaleigh's Avatar
annaleigh
annaleigh is offline
annaleigh has a good reputation on FTE.annaleigh has a good reputation on FTE.annaleigh has a good reputation on FTE.
What transmission do you have?
I believe code 67 has to do with the neutral safety switch down on the transmission...
If it is a stored code then that means it happened in the past.. Could be a loose connection or loose switch..
Old 07-08-2018, 09:35 PM
Maillemaker
E40D transmission.
I have cleared all codes by disconnecting the battery, so we will see if it comes back or not.
Steve
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
