1978 - 1996 Big Bronco
95 Front wheels wont turn left or right. HELP
Old 07-08-2018, 11:54 AM
sct6n1's Avatar
sct6n1
sct6n1 is offline
Thank you in advance for your patience, I'm new at this. 95 Bronco cannot turn wheels left or right. Driving home I stooped at an intersection, went to turn left could'nt turn the steering wheel. Got it home. Checked tie rods and drag link nothing broken. Was advised it was steering gear. Replaced steering box. Reassembled front end. Same problem. I disconnected the drag link from the pitttman arm. Jacked up the front. The front wheels wont turn left or right. Ball joints are solid. Stumped....Any help most appreciated. Need this truck for work!
Old 07-08-2018, 02:38 PM
Conanski's Avatar
Conanski
Conanski is online now
Two possibilities, ball joints are seized or the front drive axle outer U-joints are seized. Or both.
Old 07-10-2018, 06:53 PM
Redark1's Avatar
Redark1
Redark1 is offline
This just happened out of the blue. Any noise from the power steering pump. Fluid ok. Is there a steering damper on it.
when you jacked it up, you can't turn the steering wheel. Engine running or not.
Old 07-11-2018, 12:09 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
I would agree with what conanski said.
Old 07-12-2018, 10:01 AM
sct6n1's Avatar
sct6n1
sct6n1 is offline
Fluid fine. Power Steering pump only 4 months old. No leaks, pump is quiet. Serpentine belt is not worn out. Cannot turn wheels even with engine off.
Thinking axel U joints as others have said. Thank you will update
Old 07-12-2018, 10:02 AM
sct6n1's Avatar
sct6n1
sct6n1 is offline
Thank you. I will update.
gtadim
05-26-2015 07:01 AM
ch435
06-11-2011 05:32 PM
zottyzot
09-27-2010 03:29 PM
jle70
06-05-2009 09:26 AM
Quick Reply: 95 Front wheels wont turn left or right. HELP
