2002 SD 7.3 shifted from 2H to 4L on its own? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-07-2018, 11:58 PM
cbuttre835
cbuttre835 is offline
cbuttre835 is starting off with a positive reputation.
Had a new gremlin show up tonight.
Driving on a straight, smooth, flat stretch of road about 60 mph, I feel a little jerk, and then hear gears grinding. I saw the 4x4 and Low Range (or whatever it says) lamps on. I kicked it into neutral, and as I slowed on down it finally slammed into 4L.
I rigged up a 12V jumper wire and tested the motor by unplugging the 2-wire connector on the pass side of the ESOF actuator. It would try to turn but I never got the t-case out of 4L. I took the back roads on home.
I understand that I can pull that module and shift it back to 2H. actuator
What would cause this, though? I know of another truck that did the same thing, but it was built from a donor cab / bed swapped onto a rolling chassis. I chalked that up to a wiring gremlin. Should I start chasing electrical stuff, or is it a common thing for the ESOF actuator to do this?
Is there a manual shift lever retrofit?
Any guidance appreciated.
Thanks
Old 07-08-2018, 04:59 AM
seville009
seville009 is offline
seville009 is gaining momentum as a positive member of FTE.
Similar older thread.....no quick fix though
other threads indicate wiring issues into the 4Wd shifter case
https://www.ford-trucks.com/forums/9...ay-speeds.html
Old 07-08-2018, 09:42 AM
cbuttre835
I found the two relays - I think, in a small mount next to the master cylinder, had an orange and yellow heavy conductor from them which appears to go to the actuator motor. Anyhow, when I pulled them they were warm to the touch. I have 12V across both coils - (85 and 86) - a schematic I found indicated that the 86 terminal was full-time energized and the 85 terminal has ground applied to suck in the relay. That is, term 86 to chassis reads 12V (as expected), term 85 to hot reads 12V - I wouldn't expect this.
Anywho, I pulled the actuator motor so I could shift to 2H. I applied 12V to the 2 terminals in both polarities, and got no movement. I removed the plastic motor cover and the motor smells burnt, and the varnish has cooked out, also indicating this.
I assume the 4x4 control module behind the glove box supervises the operating of these relays and actuator. So, is this thing failing a common occurrence, or should I start tracing the wire harness and look for unintentional grounds?
The schematic I found is here: https://goo.gl/images/QS2MNu
TIA!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
