Which fluids to use? ZF5 and BW1356
Hi all,
I'm getting ready to install my freshly rebuilt ZF5 transmission and BW1356 transfer case into my Bronco.
I've read a lot of back and forth on fluids. My trans shop said to just get synthetic ATF and put it in both. However, Ford states that the TC requires a special transfer case fluid (XL-12) and that Mercon V is not safe in it.
What fluids are you guys using in yours? Is there a single synthetic ATF that I can safely put in both?
Or do they need different, special fluids?
Also, are some brands better than others?
Thanks
Thanks
Well, I found a really good deal on Ford's "Transfer Case Fluid" (XL-12)
Rockauto sells it for about $6 a quart, as opposed to about $15 everywhere else. So, I figured I might as well just use what Ford recommends and grabbed a few quarts. There may never be any difference between it and regular synthetic ATF, but it certainly can't hurt.
For the ZF5, I'm going to try Red Line D4 ATF
bradcdavis00
01-23-2010 05:46 AM
lwong
08-04-2004 12:23 PM
