Sponsored by: Real Truck
Smoke/steam?
Old Jul 6, 2018 | 12:39 PM
Tumble Bum's Avatar
Tumble Bum
Smoke/steam?
Hi All,
I have a 2000 F-250, with a 7.3 diesel in it. The truck is relatively new to me and I had the hood up to get the jack pieces out. The motor was running and I noticed steam/smoke coming from under a cover that said "danger or shock" on the top left hand side of the engine that is under the air intake pipe.. It didn't have any smell to it what so ever. If you revved the engine, it would disappear, but as soon as it was back at idle, it came back. I have attached two pics of the location. If anyone can help I would really appreciate it.
Thanks,
TB
Old Jul 6, 2018 | 02:23 PM
Tumble Bum's Avatar
Tumble Bum
So a more general question...what exactly is under this cover?
Old Jul 6, 2018 | 02:49 PM
sxrfun's Avatar
sxrfun
That is your CCV....Crank Case Vent.....it removes gases from the crank case and returns them to the intake. There should be 2 O rings under that to seal it against the rocker cover, you remove the 2 screws and that cover to access. My guess is one of the o rings is bad letting gasses and oil leak by.
The electrical shock warning is for I believe the wiring harness under the valve cover?
Old Jul 6, 2018 | 02:51 PM
Tumble Bum's Avatar
Tumble Bum
Will it hurt the engine to run it? That is my main concern!
Old Jul 6, 2018 | 02:56 PM
Evan_P's Avatar
Evan_P
No. When you decide to replace the o-rings get them from ford as they are specially o-rings. There are two under that breather assembly as well as 2 small ones that seal the bolts.
rterril02
Nov 3, 2016 09:22 PM
cutlass
Sep 21, 2012 01:02 AM
Rusty Shackleford
Apr 13, 2010 09:31 PM
Talyn
Aug 16, 2009 11:42 AM
muddyford75
Jul 27, 2005 05:27 PM
