TPS replacement on a 1994 E-150 351W - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-05-2018, 11:27 AM
kgmkgm
kgmkgm is offline
kgmkgm is starting off with a positive reputation.
Does this require removing the throttle body? Pretty dang tight fit to get any tools under neath the body with the coolantlines, etc.
Also is there a schematic online anywhere? I found a broken vacuum hose & elbow junction that can't be helping it run right.
Old 07-05-2018, 01:39 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Yes TB should come off.
Is there an emissions sticker on the rad support? If not can you post pics of what you found.
Old 07-05-2018, 02:49 PM
kgmkgm
kgmkgm is offline
Yeah I think its the hose from the evap can to the TB that is crumbling. I REALLY don't want to remove the TB and dump all the coolant, remove throttle cables, replace gasket, possibly break the bolts in the intake. Trying my hardest to get a screwdriver underneath
Old 07-05-2018, 07:48 PM
kgmkgm
kgmkgm is offline
Maybe I'm just used to working on my last jeep, but none of the bolts broke! Had to order Motorcraft from Oreilly (of course) but is there anything else I should replace while I'm in here? Is the coolant sensor worth replacing if its been reporting normally? Anything else that is easy to access? I am doing that one major Evap hose which is busted apart.
Old 07-11-2018, 11:15 AM
kgmkgm
kgmkgm is offline
Replacing the Evap hose from the canister to the TB...it keeps slipping off the TB nipple? It's 3/8" fuel hose, seems to fit properly, but pops off after 30 seconds. Too tight for a clamp, will a Ziptie hold it on decently?
Old 07-11-2018, 11:51 AM
kgmkgm
kgmkgm is offline
Derp, use your man hands.
fhafer
12-13-2013 05:50 PM
Christof13T
11-14-2012 10:13 PM
SmokeBlower
07-14-2007 08:30 PM
chris69bbconvertible
10-25-2006 03:01 PM
200gt
03-22-2005 08:40 PM
Quick Reply: TPS replacement on a 1994 E-150 351W
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
