What voltage does your truck run at? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 07-04-2018, 12:28 PM
L-ight
L-ight is offline
L-ight is starting off with a positive reputation.
I have seen it as high as 14.3, but lately it's been between 13.8-14.0. Though I do run the AC on recycle and full blast since it is hot here in Houston. I have recently replaced the alternator due to it not charging the batteries. I do have an aftermarket sound system, but I don't blare it every where I go. I do notice that when I turn the AC to low it bumps the voltage by (.2) or (14.0). Also lately I have notice some corrosion build up on the negative terminals and some on the positive terminals. I recently cleaned with with the baking soda/water mix which was a damn mess. Anyways I am wanting to see if I may be having an electrical charge problem or my alternator is just a POS which is from O'Reilly's.
Old 07-04-2018, 12:34 PM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
Mine is about the same as yours but it can go as high as 14.5.
Old 07-04-2018, 01:05 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Not sure I understand. Are you asking if the numbers you listed (quoted above) are a problem? If that's the question, then you're fine. Numbers will vary from truck to truck, but those are well within normal parameters.
Stewart
Old 07-04-2018, 02:43 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
You mentioned some corrosion on the terminals, a good place to start cleaning. Wire brush inside the clamps and the battery posts. Then coat with NO-OX or equivalent. I am betting that you will see some improvement.
Old 07-04-2018, 08:54 PM
Randyholton
Randyholton is offline
Randyholton is starting off with a positive reputation.
System voltage is related to what it takes to charge the battery and that changes with battery condition/ life
Old 07-04-2018, 10:41 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is offline
Wesley Green is gaining momentum as a positive member of FTE.Wesley Green is gaining momentum as a positive member of FTE.
I usually see 14.2 to 14.4 for about a minute after i first start the engine, then it pretty much holds steady at 13.8-13.9
We just drove 1900 miles cross country towing the 5th wheel and thats what it was with ac maxed, truck and trailer lights on, stock radio, and 2-5 cell phone or tablets being charged
Old 07-04-2018, 11:06 PM
IDI-Charlie's Avatar
IDI-Charlie
IDI-Charlie is online now
IDI-Charlie has a good reputation on FTE.IDI-Charlie has a good reputation on FTE.IDI-Charlie has a good reputation on FTE.
I get 14.25V constant. If I put the A/C on and blower motor on high I drop to 13.92V.
Old 07-05-2018, 06:22 AM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Originally Posted by Wesley Green View Post
I usually see 14.2 to 14.4 for about a minute after i first start the engine, then it pretty much holds steady at 13.8-13.9...
You likely have a bad glow plug circuit, unless you leave it KOEO until the GPR times out before cranking. Any time the glow plug relay is on while starting (the first few seconds to a couple of minutes, depending on engine temperature), you won't see much over 12 volts.
Old 07-05-2018, 08:19 AM
Wesley Green
True.
I guess that i should have mentioned that's with the current temps like May - September ish. When the temp is below 60 or so when the glow plugs actually come on then the voltage stays lower for about 5 minutes
Old 07-05-2018, 11:01 AM
'88 E-350
'88 E-350 is offline
'88 E-350 is gaining momentum as a positive member of FTE.
Your voltages seem fine. How much drop you see from running the AC and other stuff depends on where the gauge is connected so you can't exactly compare to other vehicles unless they're wired the same way. After neutralizing/cleaning the surface of the terminals you should disconnect and clean the contact surfaces. Then add a protectant to reduce future corrosion. Those felt discs you slide onto the posts help keep acid from coming up and attacking the cables & terminals.
Old 07-05-2018, 12:59 PM
brian42's Avatar
brian42
brian42 is online now
brian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud of
If you're above 13VDC on a H-O-T day with the system loaded then I consider that okay. If it's dipping close to 13VDC then I would be checking connections (battery and ground) to make sure they're clean and solid. Unless the battery light comes on you shouldn't have anything to worry about since you've got a new alternator IMO.
Old 07-06-2018, 11:23 AM
L-ight
L-ight is offline
Ok thanks for the replies. The lowest I have seen it is 13.8. Before I replaced the alternator it would not get above 12.5v hence why I would have a dead battery on start.
Old 07-09-2018, 05:11 PM
GEugeneS
GEugeneS is offline
GEugeneS is starting off with a positive reputation.
I've been using Vaseline for almost 60 years now and never had a corrosion problem. Also still using the same terminal clearner I bought at Pep Boys for almost 55 years. One side clean the inside of the cable connectors and the other side cleans the battery posts. This one goes for $1.73 which is probably less than I paid for in in 1964 and looks identical.
https://www.jbtoolsales.com/performa...xoCqVIQAvD_BwE
Old 07-09-2018, 05:13 PM
GEugeneS
GEugeneS is offline
BTW, I run between 13.7 and 14.3V after starting which usually pulls it down to 11 or so for a few seconds.
Old 07-09-2018, 05:41 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Eugene's been using vaseline for over 60 years and his voltage is still up!!!
LOL
Love this forum!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
