What voltage does your truck run at?
I have seen it as high as 14.3, but lately it's been between 13.8-14.0. Though I do run the AC on recycle and full blast since it is hot here in Houston. I have recently replaced the alternator due to it not charging the batteries. I do have an aftermarket sound system, but I don't blare it every where I go. I do notice that when I turn the AC to low it bumps the voltage by (.2) or (14.0). Also lately I have notice some corrosion build up on the negative terminals and some on the positive terminals. I recently cleaned with with the baking soda/water mix which was a damn mess. Anyways I am wanting to see if I may be having an electrical charge problem or my alternator is just a POS which is from O'Reilly's.
Stewart
I usually see 14.2 to 14.4 for about a minute after i first start the engine, then it pretty much holds steady at 13.8-13.9
We just drove 1900 miles cross country towing the 5th wheel and thats what it was with ac maxed, truck and trailer lights on, stock radio, and 2-5 cell phone or tablets being charged
You likely have a bad glow plug circuit, unless you leave it KOEO until the GPR times out before cranking. Any time the glow plug relay is on while starting (the first few seconds to a couple of minutes, depending on engine temperature), you won't see much over 12 volts.
Your voltages seem fine. How much drop you see from running the AC and other stuff depends on where the gauge is connected so you can't exactly compare to other vehicles unless they're wired the same way. After neutralizing/cleaning the surface of the terminals you should disconnect and clean the contact surfaces. Then add a protectant to reduce future corrosion. Those felt discs you slide onto the posts help keep acid from coming up and attacking the cables & terminals.
If you're above 13VDC on a H-O-T day with the system loaded then I consider that okay. If it's dipping close to 13VDC then I would be checking connections (battery and ground) to make sure they're clean and solid. Unless the battery light comes on you shouldn't have anything to worry about since you've got a new alternator IMO.
https://www.jbtoolsales.com/performa...xoCqVIQAvD_BwE
