78 bronco 6.6 400 wonít always start - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 07-04-2018, 03:12 AM
Dman275
Dman275 is offline
Dman275 is starting off with a positive reputation.
alright. Recently got a 78 Ford Bronco. 400
Whats going on. Sometimes it just wonít start. Sometimes Iíll try it, nothing. Leave it alone come back the next day fires right up. Or Iíll drive around all day no problems then go to leave and nothing. Looks like the previous owner was haveing the issue too. It has a new ignition relay. Battery. Voltage regulator. Starter. Ignition coil And ignition control module. Iíve looked through most wires. Donít see anything loose. Idk what to try next. So what happens when itís not starting. I turn the key and hear a kind of boing. I believe the ignition coil. And the brake light comes on. And thatís it. Put in the last part today. Fired right up. Drive around a bit. Went to the store and first turn nothing. Second then. It slowly fired up.
Old 07-04-2018, 08:17 AM
schwim's Avatar
schwim
schwim is offline
schwim is starting off with a positive reputation.
I'm going to guess the neutral safety switch circuit. I had the same problem and found that someone had bodged bypassing the switch when they swapped out the auto for a manual trans.
Old 07-04-2018, 01:46 PM
Dman275
Dman275 is offline
Idk cuz Iíve tried starting it from neutral not just park. And nothing. And if it where the switch the starter solenoid wouldnít open right?
Old 07-04-2018, 06:11 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
You should go investigate it.
If you ask for ideas, don't be so ready to dismiss them unless with out a doubt you have ruled it out
Old 07-04-2018, 07:00 PM
packagerjr
packagerjr is offline
packagerjr is gaining momentum as a positive member of FTE.packagerjr is gaining momentum as a positive member of FTE.
Iím still a bit confused on what youíre hearing when you turn the key to Run but it doesnít start. If you hear the starter solenoid thump then your ignition and NSS circuits should be good. If itís not cranking youíve got an issue from the solenoid to the starter. If itís cranking but not firing then it could be air, fuel, or spark.
Have you replaced the ignition switch on the column?
Old 07-10-2018, 08:53 PM
Redark1
Redark1 is offline
Redark1 is starting off with a positive reputation.
Dont forget the pickup coil in the distributor.
when you said it started slowly explain that more please.
Old 07-11-2018, 11:30 PM
e.lair
e.lair is offline
e.lair is starting off with a positive reputation.
I had the same problem with my 5.8. I changed out the fuel pressure regulator and havenít had a problem since.
Old 07-12-2018, 12:11 AM
McLeod's Avatar
McLeod
McLeod is offline
A 78 in stock configuration doesn't have an FP regulator
Old 07-15-2018, 08:38 PM
EDC8008
EDC8008 is offline
EDC8008 has a good reputation on FTE.EDC8008 has a good reputation on FTE.
So some times cranks right up, sometimes just the starter solenoid clicks (boing), and some time starts turning slowly?
I would suspect;
1 Starer Solenoid (rare to be bad if new but does happen)
2 Cable from solenoid to starter
3 Bad Starter Ground or engine to chassis grounds (check them all)
4 Bad starter. 1 or 2 bad windings will cause no rotation when you try to start then it’ll catch and drag or fire right up. Mine’s doing this now but it has to wait for my shoulder to finish healing for me to replace it
BCO2JCO
03-18-2008 06:06 PM
mx495
09-17-2007 06:24 PM
alm94
Electrical Systems/Wiring
07-19-2004 02:16 PM
NDS
04-05-2003 12:28 AM
explorerdad
09-05-2001 07:39 PM
Quick Reply: 78 bronco 6.6 400 wonít always start
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
